MQTT Broker and MQTT bridge Exe and DLL files.
4 posts / 0 new
Last post
manish ojha
Dear Sir,
I am working on the getting the meter data thru MQTT , for which I downloaded the codes fo the Gurux MQTT folder, But i am unable to work as .dll and exe files are missing.
How do i can get the same, Please help.
Regards
Manish Ojha
Kurumi's picture
Dear Manish Ojha,
You need to build the application. You can try to run "dotnet build" in that folder. It will build the application.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
manish ojha
Dear Sir
I build the code but it is giving the error message as per attached screen shot, where i am missing. please help
Image:
Manish Ojha
Kurumi's picture
Hi Manish,
This is not an exe that you try to run. Try to run bridge and broker to get started.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
