I am facing below issue while writing Activity calendar- Passive day profile to the meter.
gurux.dlms.GXDLMSException: Access Error : Device reports a unmatched type.
----------CODE---------------------
GXDLMSActivityCalendar ac = new GXDLMSActivityCalendar(OBIS_ACTIVITY_CALENDAR);
com.readObject(ac, INDEX_PASSIVE_DAY_PROFILE_TABLE); //Reading index data
ac.setDayProfileTablePassive(new GXDLMSDayProfile[] {dp});
com.writeObject(ac, INDEX_PASSIVE_DAY_PROFILE_TABLE); // Writing Day Profile
There is nothing that we can do about this. I checked the bytes and everything is correct.
This is a meter issue.
If you compare read and write trace you will notest that the payload is the same. I believe that you have read and try to write the same data. Ask the meter manufacturer to fix it.
Thank you Mikko.. I will
Thank you Mikko.. I will contat the manufacturere team.
