LG and Gurux.DLMS.Simulator
4 posts / 0 new
Last post
OK1FMD
I have problem with Gurux.DLMS.Simulator.
When I want to run the Gurux.DLMS.Simulator it shows me the following error:
Invalid device template file simulator_template.xml
Command:
C:\dlms\GuruX\GitHub\CSharp\Gurux.DLMS.Net\Gurux.DLMS.Net-master\Gurux.DLMS.Simulator.Net\bin\Release>Gurux.DLMS.Simulat
or.Net.exe -p 8000 -x simulator_template.xml -t Verbose -N 10
DLMS HDLC Logical Name simulator start in ports 8000-8009.
Can you help me, please?
Thanks and Best Regerds
Martin
Kurumi's picture
Hi Martin,
Have you read all values from the meter and create the simulator template? Something like this:
Gurux.DLMS.Simulator.Net.exe -S COM8 -o simulator_template.xml -t Verbose
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
OK1FMD
thanks for your answer. I reading all values from the meter. I will try to creating simulator template. I need to find out the value of the total data volume of the data reading. Can you advise me? How to do it?
Martin
Kurumi's picture
First read the values from the meter and then start the simulator.
Check this:
https://www.gurux.fi/Gurux.DLMS.Simulator
Find Usage -topic. It'll describe what you need to do.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
