Currently I am using old version of Gurux.DLMS.cpp-master based on Visual Studio 2012. This method ( GXDLMSCLient.UseUtc2NormalTime) is not available here. I have downloaded the latest version of Gurux.DLMS.cpp-master but it based on visual studio 2019. I am unable to use visual-studio-2019. I can use use visual studio 2017 max.
Could this matter resolve in visual studio 2017?
If yes, then how will I get Gurux.DLMS.cpp-master based on visual studio 2017?
I have migrated to latest version (Gurux.DLMS.cpp-master-Version 20201127.1 ). I have tried this (GXDLMSCLient.UseUtc2NormalTime) as suggested by you but filtered data data records are same.
As I was facing the issue between the input time range and out put time range for block profile object is differ. But if I check the same scenario with DLMSDirector tool, then the result set is ok.
I have checked the above scenario with latest code as you had suggested me to add "cl.SetUseUtc2NormalTime(true)" but still I am getting the differences in result set.
Kindly find the below mentioned sample code and attached screenshot of DLMSDirector tool.
which line have I missed in the sample code? Kindly check.
Can you add a trace from the request bytes in hex string to here so I can check the bytes?
Your code seems correct for the first sign, but I need the bytes to verify this.
You need to set GXDLMSCLient.UseUtc2NormalTime to true.
Pradson
Hi Pradson,
Hi Pradson,
You can use the old project and solution file. Just update *.h and *.cpp files to the latest one.
I did as suggested by you but facing a lots of complier errors.
I am using visual-studio-2012 to build the same.
Kindly suggest any other solution?
Thanks & Regards,
Pradson
You need to add all header and cpp files to the project. There are no reasons why it shouldn't compile with VS 2012.
HI Mikko,
HI Mikko,
How will I get older version Gurux.DLMS.cpp-master which could build in visual studio 2017?
Try to get this and then add all new header and cpp files.
https://github.com/Gurux/Gurux.DLMS.cpp/commit/b45e49be4bb9f4c1a50d0ccc…
Kindly check.
Pradson
HI Mikko,
HI Mikko,
// ------------------- sample Code ---------------------
cl.SetUseUtc2NormalTime(true); // As suggest
/*********** read clock ***********/
CGXDLMSClock *objClock = new CGXDLMSClock("0.0.1.0.0.255");
std::string sValues;
if ((ret = comm.Read(objClock, 2, sValues)) != 0) {
printf("err! failed to read clock object register: %s \n", CGXDLMSConverter::GetErrorMessage(ret));
else {
printf("sValues: %s\n", (char*)sValues.c_str());
CGXDLMSProfileGeneric *objLP1 = new CGXDLMSProfileGeneric("1.0.99.1.0.255");//Block profile
ret = 0;
std::string sCapObj;
if ((ret = comm.Read(objLP1, 3, sCapObj)) != 0)
printf("err! failed to readCaptureObjects: %s \n", CGXDLMSConverter::GetErrorMessage(ret));
CGXDateTime startLP1 = CGXDateTime(2020, 11, 26, 22, 0, 0, 0);
CGXDateTime endLP1 = CGXDateTime(2020, 11, 26, 23, 0, 0, 0);
CGXDLMSVariant rows;
if ((ret = comm.ReadRowsByRange(objLP1, startLP1, endLP1, rows)) != 0) {
printf("err! failed to read register: %s \n", CGXDLMSConverter::GetErrorMessage(ret));
else {
printf("sValues:\n%s", (char*)rows.ToString().c_str());
// ------------------- Out put of sample Code ---------------------
sValues: 07-12-2020 16:43:52
sValues:
27-11-2020 09:00 | 4998 | 57845 | 57820 | 57833 | 0 | -86158 | 86158 | 0 | 0 | 75434 | 0 | 57832 | 4294967295 | -75434 | 264 | 264 | 264 | 0 | -75434 | 0 | 752 |
27-11-2020 09:15 | 4998 | 57897 | 57876 | 57887 | 0 | -37670 | 37670 | 0 | 0 | 32234 | 0 | 57886 | 4294967295 | -32234 | 114 | 114 | 114 | 0 | -32234 | 0 | 759 |
27-11-2020 09:30 | 4998 | 57932 | 57907 | 57918 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 57919 | 4294967295 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
27-11-2020 09:45 | 4998 | 57917 | 57898 | 57912 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 57909 | 4294967295 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
27-11-2020 10:00 | 4998 | 57913 | 57892 | 57906 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 57903 | 4294967295 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
Pradson
Kindly find the text of trace file-
TX: 15:36:44 00 01 00 20 00 11 00 35 60 33 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 07 80 05 73 73 73 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
RX: 15:36:44 00 01 00 11 00 20 00 2A 61 28 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 0F 04 0D 08 00 06 5F 04 00 00 10 1D 20 00 00 07
TX: 15:36:46 00 01 00 20 00 11 00 0D C0 01 81 00 08 00 00 01 00 00 FF 02 00
RX: 15:36:46 00 01 00 11 00 20 00 12 C4 01 81 00 09 0C 07 E4 0C 08 02 0F 25 0E 16 01 4A 00
TX: 15:36:47 00 01 00 20 00 11 00 0D C0 01 81 00 07 01 00 63 01 00 FF 03 00
RX: 15:36:47 00 01 00 11 00 20 01 92 C4 01 81 00 01 16 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0E 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 20 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 34 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 48 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 10 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 06 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 07 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 08 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 0E FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 80 07 59 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 6E FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 1F 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 33 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 47 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0D 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 54 1B 00 FF 0F 02 12 00 00
TX: 15:36:47 00 01 00 20 00 11 00 40 C0 01 81 00 07 01 00 63 01 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E4 0B 1A 07 16 00 00 FF FE B6 00 09 0C 07 E4 0B 1A 07 17 00 00 FF FE B6 00 01 00
RX: 15:36:47 00 01 00 11 00 20 02 63 C4 01 81 00 01 05 02 16 09 0C 07 E4 0B 1B FF 09 00 FF FF 01 4A 00 06 00 00 13 86 06 00 00 E1 F5 06 00 00 E1 DC 06 00 00 E1 E9 06 00 00 00 00 05 FF FE AF 72 06 00 01 50 8E 06 00 00 00 00 06 00 00 00 00 06 00 01 26 AA 06 00 00 00 00 06 00 00 E1 E8 06 FF FF FF FF 05 FF FE D9 56 06 00 00 01 08 06 00 00 01 08 06 00 00 01 08 05 00 00 00 00 05 FF FE D9 56 06 00 00 00 00 06 00 00 02 F0 02 16 09 0C 07 E4 0B 1B FF 09 0F FF FF 01 4A 00 06 00 00 13 86 06 00 00 E2 29 06 00 00 E2 14 06 00 00 E2 1F 06 00 00 00 00 05 FF FF 6C DA 06 00 00 93 26 06 00 00 00 00 06 00 00 00 00 06 00 00 7D EA 06 00 00 00 00 06 00 00 E2 1E 06 FF FF FF FF 05 FF FF 82 16 06 00 00 00 72 06 00 00 00 72 06 00 00 00 72 05 00 00 00 00 05 FF FF 82 16 06 00 00 00 00 06 00 00 02 F7 02 16 09 0C 07 E4 0B 1B FF 09 1E FF FF 01 4A 00 06 00 00 13 86 06 00 00 E2 4C 06 00 00 E2 33 06 00 00 E2 3E 06 00 00 00 00 05 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 E2 3F 06 FF FF FF FF 05 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 05 00 00 00 00 05 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 16 09 0C 07 E4 0B 1B FF 09 2D FF FF 01 4A 00 06 00 00 13 86 06 00 00 E2 3D 06 00 00 E2 2A 06 00 00 E2 38 06 00 00 00 00 05 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 E2 35 06 FF FF FF FF 05 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 05 00 00 00 00 05 00 00 00 00 06 00 00 00 00 06 00 00 00 00 02 16 09 0C 07 E4 0B 1B FF 0A 00 FF FF 01 4A 00 06 00 00 13 86 06 00 00 E2 39 06 00 00 E2 24 06 00 00 E2 32 06 00 00 00 00 05 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 E2 2F 06 FF FF FF FF 05 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 05 00 00 00 00 05 00 00 00 00 06 00 00 00 00 06 00 00 00 00
TX: 15:36:50 00 01 00 20 00 11 00 05 62 03 80 01 00
RX: 15:36:50 00 01 00 11 00 20 00 02 63 00
Pradson
Hi Pradson,
Hi Pradson,
There was an error with UseUtc2NormalTime. This is now fixed. Get the latest version.
Yes, it working now.
Thanks a lot for your kind help.
Thanks & Regards,
Pradson
