By Jung Sang Hoon, 1 December, 2020 Forums General discussion I want to do serial communication using the gurux DLMS Client Example of GuruxDLMS.c, but I am curious how to set it up. Image Hi, Hi, Picture is compressed and I can't read it clearly, but if you are using serial port connection you need to set serial port parameters like this: -P COM3 ANSI C expects that settings are 8None1. If your meter is using something else you need to change then to the source code. BR, Mikko Log in or register to post comments
-P COM3
