Some settings/parameters are fixed (Same) for all devices, only certain settings will change for each device.
But if I try to change anything except for the device name and physical address, I have the message "No Device Template Available", in the new version the device settings revert back to the template settings.
So, I have to create one device template for each group of devices which differ only in name and physical address. In my case this will be a lot of templates.
Is this logical, and if it is how can I bypass it?
This is an issue. I created an issue from this.
https://www.gurux.fi/node/17169
We'll fix this and release a new version later today.
This is fixed and a new version is released.
