Dear,
What is the command for manually disconnecting the connection while using the GXDLMSXMLClient? I have tried the <DisconnectRequest /> like how it was in the GXDLMSDirector but I get an error saying "invalid command".
Best Regards
Pramod
Java Xml client doesn't support DisconnectRequest. It's now added. Get the latest version from GitHub. A new version is released next month until that you need to use the GitHub version.
Dear Pramod,
Dear Pramod,
If you are using WRAPPER you should call release.
Thank you Mikko, Should I use
Thank you Mikko, Should I use <Release /> in the XML messages. Is this different for HDLC or the same would work with HDLC?
BR
Pramod
