Meter returns system title in AARE, but it can't be validated because the only thing that is required from the system title is size. It must be 8 bytes long. Usually system title consists of the FLAG and serial number, but that is not used in all the meters or sub-standards from DLMS.
Can you please provide an update on this?
Mikko,
Mikko,
Thanks for the update.
So, If we have multiple meters with different serial numbers and having the same configuration then is there any way to validate the request.
From the configuration point of view can we identify the request is valid for that meter or not?
If you are using the same communication channel, like RS-485 for all the meter you need to use the serial number as a server address.
