By enhee88009932, 17 September, 2020 Forums Gurux.Serial how to read data end send request. DTZY217 i need reed parameters i need DTZY217 wire smart meters parameters. help me ? DLMS / cosem compliant support . address : 21 obis code : 21.11.1 serial port: com6 Hello, Hello, Download GXDLMSDirector and try to connect with that. You can select Gurux to the manufacturer and try to connect. i need c# example code. i need c# example code. please Hi, Hi, Read the meter first with GXDLMSDirector. When your settings are correct you can use client example to read it. https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E… BR, Mikko Log in or register to post comments
