By k Anand, 11 September, 2020 Forums General discussion Dear Sir, My query is what is the error TAG the meter should return, if any DLMS client sent Get Request after AARQ while authentication is HLS. Regards Sreeman. Dear Sreeman, Dear Sreeman, From the BB: If the authentication is not accepted, then the result parameter in the response shall contain a non-OK value, and no data shall be sent back. Some meters are also returning empty octet-string. BR, Mikko Thanking you Sir, Thanking you Sir, i will try with empty octet-string. Regards Sreeman. Hi, Hi, In the long-term, it might be better to return a non-OK value. BR, Mikko Log in or register to post comments
Dear Sreeman,
Dear Sreeman,
From the BB:
Thanking you Sir,
Thanking you Sir,
Regards
Sreeman.
