ProfileGeneric capture objects read error
6 posts / 0 new
Last post
MNN
Hello.
I try to read 0.1.99.98.4.255 and an error occurred:
fail: Gurux.DLMS.AMI.Reader.ReaderService[0]
Failed to Read 0.1.99.98.4.255:2. Capture objects not read.
Kurumi's picture
There might be a lot of reasons why it fails. Can you read it with GXDLMSDirector?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
MNN
Hello.
In the GXDLMSDirector, the profileGeneric were considered successfully. But when you read it again, the error is again
Image:
Kurumi's picture
We can't repeat this. Have you modified the source code?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
MNN
Hello.
I downloaded the latest version of AMI. In the director, I added a device, then added it as a template in AMI. Read object 0.0.98.1.1.255, then another object, then 0.0.98.1.1.255 again. An error has occurred.
The first time the object is read, the second time - an error. This happens with all profile generic objects.
Database - sqlite.
MNN
Hello.
In the assembly of the end of july, reading worked without errors. Early August build - errors reading attribute 2.
