By lara.wakim, 1 September, 2020 Forums General discussion Hi, Can you please give us an example of the command line arguments that we need to set in the project properties in order to select a proper serial com port? Best Regards, Lara Wakim Hi, Hi, You can run it using arguments like: -S SERIAL_PORT_NUMBER -t Verbose SERIAL_PORT_NUMBER depends on the serial port that you want to use. BR, Mikko Log in or register to post comments
