Save the updated key in the file system
Project:
gurux.dlms.c
We are working on the server example 2.
In this example, we are creating an object of type definition GXSerializedMeterData that contains several interface classes. This object is constantly saved to the file system (on the memory in case of micro-controller) so the changed settings are protected even with the lost of power.
However, we noticed that the ciphering key as the authentication key and the block cipher key are not saved in case the user changed them. In fact though the security setup object, the user can use the update action to change the key. Afterwards, this key should be saved on the memory so the updated data wouldn't be lost when the power is lost.
Best Regards,
Lara Wakim
Status:
Closed (fixed)
Priority:
Normal
Category:
Feature request
Component:
Code
Reporter:
lara.wakim
Created:
Wed, 07/29/2020 - 11:41
Updated:
Fri, 08/07/2020 - 08:26
Comments
Administrator's picture
Status: Active » Closed (fixed)
