By fernando, 21 July, 2020 Forums Gurux.DLMS Good morning, When will you have serial communication on the server side? how could you test serial communication in c? Thank you Hi, Hi, Server example for ANSI C doesn't support serial port connection at the moment. The client example does support also serial port connection. BR, Mikko Log in or register to post comments
