I am reading the Indian standard meter IS15959-2 by the following command sequence.
- Read invocation counter from the meter using public client association.
(SNRM, AARQ, READ IC, Disconnect)
- Read clock from the meter using utility association.
(SNRM, AARQ, READ Clock, Disconnect)
Invocation counter successfully read from the meter. But when reading Clock from a meter , in that AARE validation failed and get Invalid Tag exception.
I have set client configuration as per the utility association after reading the invocation counter.
Can you add bytes that meter reply when it fails?
