ActivityCalendar reading error
19 posts / 0 new
Last post
Valeriy
Hello!
Tried to read ActivityCalendar using Director + Ami and got an exception
System.Data.SQLite.SQLiteException: "SQL logic error
unrecognized token: "'""
Kurumi's picture
I just checked this and it works without problems.
Check that you are using the latest version from Gurux.DLMS.AMI.
Can you paste generated SQL string here? You can get it if you move the mouse over arg.
What attribute index did you try to read.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Valeriy
Hello!
Updated Gurux.DLMS.AMI
The same error.
About the arg =
arg
{UPDATE GXAttribute SET "Value" = '
Joins: {Gurux.Service.Orm.GXJoinCollection}
Settings: {SqLite}
Where: {WHERE "Id" = 243}
The object is highlighted in the picture. I tried to read it.
Image:
Kurumi's picture
Update GXDLMSDirector to the latest version and try again.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Valeriy
Updated. But still the same error.
Kurumi's picture
What you try to update?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Valeriy
Downloaded AMI from git and Director asked me to update. I confirmed.
One remark - I tried to read ActivityCalender by Director using Gurux.DLMS.AMI.
Valeriy
GURUX.DLMS.AMI was updated.
GURUX.DIRECTOR was updated.
Kurumi's picture
I mean what did you try to read or write? What action did you make when this occurred?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Valeriy
I tried to read ActivityCalender 0.1.13.0.1.255
Marked in the picture. Connected to the meter, selected the object, tried to read it.
Valeriy
As an example - I tried to read Atbitrator and ActivityCalendar after that.
In ValueController.css in line 110 for ActivityCalendar got error. The same as above.
For Arbitrator arg value looks like:
{UPDATE GXAttribute SET `Value` = '<Array>
<Structure>
<OctetString Value="00 66 0A 00 6C FF" />
<UInt16 Value="3" />
</Structure>
<Structure>
<UInt16 Value="4" />
</Structure>
<Structure>
<UInt16 Value="1" />
</Structure>
<Structure>
<UInt16 Value="2" />
</Structure>
</Array>
', `Read` = '2020-07-06 17:06:47' WHERE `Id` = 212}
For ActivityCalendar (where the error occures):
And nothing more.
Kurumi's picture
Activity Calendar is now tested with several meters and it works without problems.
Can you read the Activity Calendar with GXDLMSDirector and add trace here. Add just Activity Calendar read trace, nothing more.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Valeriy
11:31:40 Read object type ActivityCalendar index: 2
TX: 7E A0 19 03 0F 3E 20 AB E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 02 00 FA 0B 7E
11:31:40
RX: 7E A0 1B 0F 03 12 3B 75 E6 E7 00 C4 01 C1 00 09 09 00 00 00 00 00 00 00 00 00 73 B0 7E
11:31:40 Read object type ActivityCalendar index: 3
TX: 7E A0 19 03 0F 50 58 21 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 03 00 22 12 7E
11:31:40
RX: 7E A0 12 0F 03 34 6C C8 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:40 Read object type ActivityCalendar index: 4
TX: 7E A0 19 03 0F 72 48 23 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 04 00 2A 5F 7E
11:31:40
RX: 7E A0 12 0F 03 56 78 88 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:40 Read object type ActivityCalendar index: 5
TX: 7E A0 19 03 0F 94 70 A1 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 05 00 F2 46 7E
11:31:40
RX: 7E A0 12 0F 03 78 04 40 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:40 Read object type ActivityCalendar index: 6
TX: 7E A0 19 03 0F B6 60 A3 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 06 00 9A 6C 7E
11:31:40
RX: 7E A0 1B 0F 03 9A 7B 7D E6 E7 00 C4 01 C1 00 09 09 43 41 4C 49 4D 50 00 00 00 27 5D 7E
11:31:40 Read object type ActivityCalendar index: 7
TX: 7E A0 19 03 0F D8 18 29 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 07 00 42 75 7E
11:31:40
RX: 7E A0 6A 0F 03 BC B1 7F E6 E7 00 C4 01 C1 00 01 04 02 03 09 01 01 09 0C FF FF 0B 01 FF 00 00 00 FF 80 00 FF 09 01 01 02 03 09 01 82 09 0C FF FF 0B 01 FF 00 00 00 FF 80 00 FF 09 01 00 02 03 09 01 83 09 0C FF FF 05 01 FF 00 00 00 FF 80 00 FF 09 01 00 02 03 09 01 04 09 0C FF FF 06 01 FF 00 00 00 FF 80 00 FF 09 01 02 DC F0 7E
11:31:40 Read object type ActivityCalendar index: 8
TX: 7E A0 19 03 0F FA 08 2B E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 08 00 8A F6 7E
11:31:41
RX: 7E A0 38 0F 03 DE C5 D3 E6 E7 00 C4 01 C1 00 01 02 02 08 09 01 01 11 01 11 01 11 01 11 01 11 01 11 02 11 02 02 08 09 01 02 11 03 11 03 11 03 11 03 11 03 11 04 11 04 EB DF 7E
11:31:41 Read object type ActivityCalendar index: 9
TX: 7E A0 19 03 0F 1C 30 A9 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 09 00 52 EF 7E
11:31:41
RX: 7E A8 89 0F 03 F0 BE 3C E6 E7 00 C4 01 C1 00 01 04 02 02 11 01 01 02 02 03 09 04 07 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 02 03 09 04 16 00 00 00 09 06 00 01 0A 00 64 FF 12 00 02 02 02 11 02 01 02 02 03 09 04 00 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 02 03 09 04 17 2D 00 00 09 06 00 01 0A 00 64 FF 12 00 02 02 02 11 03 01 02 02 03 09 04 06 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 02 03 09 04 16 00 53 81 7E
11:31:41
TX: 7E A0 07 03 0F 31 34 3E 7E
11:31:41
RX: 7E A0 1C 0F 03 F2 14 C5 00 00 09 06 00 01 0A 00 64 FF 12 00 02 02 02 11 04 01 00 2B 29 7E
11:31:41 Read object type ActivityCalendar index: 10
TX: 7E A0 19 03 0F 5E 26 C8 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 0A 00 3A C5 7E
11:31:41
RX: 7E A0 1E 0F 03 14 5A 7E E6 E7 00 C4 01 C1 00 09 0C FF FF FF FF FF 00 00 FF FF 80 00 FF 94 42 7E
11:31:41 Read object type ActivityCalendar index: 2
TX: 7E A0 19 03 0F 70 5A 00 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 02 00 41 17 7E
11:31:41
RX: 7E A0 1B 0F 03 36 1D 12 E6 E7 00 C4 01 C1 00 09 09 00 00 00 00 00 00 00 00 00 73 B0 7E
11:31:41 Read object type ActivityCalendar index: 3
TX: 7E A0 19 03 0F 92 46 C4 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 03 00 99 0E 7E
11:31:41
RX: 7E A0 12 0F 03 58 06 61 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:41 Read object type ActivityCalendar index: 4
TX: 7E A0 19 03 0F B4 72 80 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 04 00 91 43 7E
11:31:41
RX: 7E A0 12 0F 03 7A 16 63 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:41 Read object type ActivityCalendar index: 5
TX: 7E A0 19 03 0F D6 66 C0 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 05 00 49 5A 7E
11:31:41
RX: 7E A0 12 0F 03 9C 2E E1 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:41 Read object type ActivityCalendar index: 6
TX: 7E A0 19 03 0F F8 1A 08 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 06 00 21 70 7E
11:31:41
RX: 7E A0 1B 0F 03 BE 5D 1A E6 E7 00 C4 01 C1 00 09 09 43 41 4C 45 58 50 00 00 00 C7 FE 7E
11:31:41 Read object type ActivityCalendar index: 7
TX: 7E A0 19 03 0F 1A 06 CC E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 07 00 F9 69 7E
11:31:41
RX: 7E A0 12 0F 03 D0 46 69 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:41 Read object type ActivityCalendar index: 8
TX: 7E A0 19 03 0F 3C 32 88 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 08 00 31 EA 7E
11:31:41
RX: 7E A0 12 0F 03 F2 56 6B E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
TX: 7E A0 19 03 0F 5E 26 C8 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 09 00 E9 F3 7E
11:31:41
RX: 7E A0 12 0F 03 14 6E E9 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
TX: 7E A0 19 03 0F 70 5A 00 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 0A 00 81 D9 7E
11:31:41
RX: 7E A0 1E 0F 03 36 4A 7C E6 E7 00 C4 01 C1 00 09 0C FF FF FF FF FF 00 00 FF FF 80 00 FF 94 42 7E
TX: 7E A0 19 03 0F 92 46 C4 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 02 00 8C 32 7E
11:31:42
RX: 7E A0 1B 0F 03 58 65 98 E6 E7 00 C4 01 C1 00 09 09 00 00 00 00 00 00 00 00 00 73 B0 7E
11:31:42 Read object type ActivityCalendar index: 3
TX: 7E A0 19 03 0F B4 72 80 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 03 00 54 2B 7E
11:31:42
11:31:42 Read object type ActivityCalendar index: 4
TX: 7E A0 19 03 0F D6 66 C0 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 04 00 5C 66 7E
11:31:42
11:31:42 Read object type ActivityCalendar index: 5
TX: 7E A0 19 03 0F F8 1A 08 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 05 00 84 7F 7E
11:31:42
RX: 7E A0 12 0F 03 BE 3E E3 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:42 Read object type ActivityCalendar index: 6
TX: 7E A0 19 03 0F 1A 06 CC E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 06 00 EC 55 7E
11:31:42
RX: 7E A0 1B 0F 03 D0 25 90 E6 E7 00 C4 01 C1 00 09 09 43 41 4C 44 53 4E 00 00 00 E3 D0 7E
11:31:42 Read object type ActivityCalendar index: 7
TX: 7E A0 19 03 0F 3C 32 88 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 07 00 34 4C 7E
11:31:42
11:31:42 Read object type ActivityCalendar index: 8
TX: 7E A0 19 03 0F 5E 26 C8 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 08 00 FC CF 7E
11:31:42
11:31:42 Read object type ActivityCalendar index: 9
TX: 7E A0 19 03 0F 70 5A 00 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 09 00 24 D6 7E
11:31:42
RX: 7E A0 12 0F 03 36 7E EB E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:42 Read object type ActivityCalendar index: 10
TX: 7E A0 19 03 0F 92 46 C4 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 0A 00 4C FC 7E
11:31:42
RX: 7E A0 1E 0F 03 58 32 F6 E6 E7 00 C4 01 C1 00 09 0C FF FF FF FF FF 00 00 FF FF 80 00 FF 94 42 7E
Valeriy
Selected item.
Image:
Kurumi's picture
Your meter is returning hex(000000000000000000) as active calendar name and it was causing this.
This is now fixed. The active calendar name is now empty.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Valeriy
Thanks for your help.
Valeriy
Everything is ok using web. But problem using Director (with Ami).
Director without Ami reads full name of the calendar. But if we start to use Ami for reading - only first two characters.
Picture attached.
Image:
Kurumi's picture
I know the reason for this. We are implementing GXDLMSDirector UI so it can show non-ASCII Activity Calendar names.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Valeriy
Kiitos avusta!
