By MNN, 16 June, 2020 Forums Gurux.DLMS.AMI Hi, an error occurs when switching beatween nodes: failed to cast object type "Gurux.DLMS.GXDLMSMeter" to type "GXDLMSDirector.GXDLMSDevice". Image Hi, Hi, Is this happening with the new version? What node did you selected? We can't repeat this. BR, Mikko Hi, Hi, Thank you! There is no problem in the new version. Log in or register to post comments
