Is there a library that can be used to pack data (data to xml) before transferring to 1 for writing to the device? Or is it possible to make the data transferred as is (in object GXObject), and the packaging (data to xml) was in ami?
Thank you.
I am trying to use ami on a web. Tell me, please, can I use existing methods for packing the data before send it to write in ami, as well as for unpacking complex data (such as structures, arrays), which are receive as xml in ami?
As far as I understand method ValueToXml receive only symple type.
Data must convert value to XML before sending it to the Gurux.DLMS.AMI. You can use GXDLMSTranslator.ValueToXml -method for that.
Thank you.
Thank you.
ValueToXML support also complex data types. Use it to convert value to XML format.
