Time event driven interface classes
Project:
gurux.dlms.c
All time driven interface classes do not seem to be implemented yet in the Gurux server example 2.
1. The Profile Generic (ID = 7) that should periodically trigger the method capture depending on the capture period introduced.
2. The Single Action Schedule (ID = 22) that should trigger the execution of the executed script on the execution time specified.
In the development folder, I found the file “server.c” that includes the function svr_run() that intends to call the functions : svr_handleProfileGeneric() and svr_handleSingleActionSchedule(). These two functions have been probably written to execute the actions listed above.
However, the function svr_run() has never been called and used in the Gurux server example 2.
Can you implement this feature?
Status:
Closed (fixed)
Priority:
Major
Category:
Feature request
Component:
Code
Reporter:
lara.wakim
Created:
Thu, 06/11/2020 - 14:23
Updated:
Fri, 06/12/2020 - 16:16
Comments
Administrator's picture
Status: Active » Closed (fixed)
