Cannot read the values of active energy.
Project:
Gurux.DLMS.Python
When I do get the talk to the meter, I cannot get the values out of the active energy unit:
-------- Reading 3 2992 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 1 (0 is total)
Index: 1 Value: 1.1.1.8.1.255
Index: 3 Value: 0.1, Unit.ACTIVE_ENERGY
Error! Index: 2 Access Error : Device reports Read-Write denied.
Same for:
1.1.2.8.0.255
1.1.1.8.0.255
Status:
Closed (won't fix)
Priority:
Major
Category:
Feature request
Component:
Code
Reporter:
ilhan
Created:
Thu, 06/04/2020 - 18:22
Updated:
Fri, 06/05/2020 - 08:22
Comments
Kurumi's picture
This is not an issue. You must ask is this implemented to the meter from the meter vendor or if you need to use different authentication level.
Kurumi's picture
Status: Active » Closed (won't fix)
