connecting to landis+gyr ZMD410CT
20 posts / 0 new
Last post
Pezet032
I trying to connect to landis+gyr ZMD410CT which is connected to virtual com port by optical interface.
The com port works fine but when I'm trying to connect with Gurux i get "Filed to recive replay from the device in given time" replay. I checked initial settings but the manual seems out of date. Can enyone help ?
Kurumi's picture
If you are using optical port change "Start Protocol" from DLMS to IEC.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Pezet032
It doesn't help. I tried a lot of different combinations but always this same problem occurs.
When i'm using telnet with standard frame "/?! " i'm getting an answer.
BR
Piter
Best regards
Piter
Kurumi's picture
Hi Piter,
"/?! " is IEC message. Are you getting any reply when you are using IEC as a start protocol?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Pezet032
Nope, u can see below, I read that the optical interface needs handshake before connection, but it starts with SNRM frame.
13:13:33 Send SNRM request.
13:13:38 Data send failed. Try to resend 1/3
13:13:43 Data send failed. Try to resend 2/3
13:13:48 Failed to receive reply from the device in given time.
13:13:48 Send Disconnect request.
13:13:53 Data send failed. Try to resend 1/3
13:13:58 Data send failed. Try to resend 2/3
13:14:03 Failed to receive reply from the device in given time.
BR
Piter
Best regards
Piter
Kurumi's picture
Have you changed this?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Pezet032
Yes offcourse.
Image:
Best regards
Piter
Kurumi's picture
In your first post you said that you are using a virtual com port. Do you have a virtual COM port or are you using an optical probe (head) that is connected to USB?
Try to select "Use maximum baud rate". It helps with some optical probes. Communication is slow, but you can check if communication works.
What optical probe you are using (modem and manufacturer)?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Pezet032
That was helpful. I set the "use max baud rate" and I got first anwser.
I'm using numeron optical head with rs232 port via ser2net.
[26/05/2020 08:23:45] Written data (COM4)
2f 3f 21 0d 0a /?!..
[26/05/2020 08:23:46] Read data (COM4)
2f 4c 47 5a 35 5c 32 5a 4d 44 34 31 30 34 34 30 /LGZ5\2ZMD410440
39 2e 42 32 34 0d 0a 9.B24..
[26/05/2020 08:23:47] Written data (COM4)
06 32 30 32 0d 0a .202..
[26/05/2020 08:23:47] Read data (COM4)
[26/05/2020 08:23:48] - Close port COM4
[26/05/2020 08:23:48] - Open port COM4
[26/05/2020 08:23:49] Written data (COM4)
7e a0 07 03 21 93 0f 01 7e ~ ..!“..~
[26/05/2020 08:23:54] Written data (COM4)
[26/05/2020 08:24:00] Written data (COM4)
[26/05/2020 08:24:05] Written data (COM4)
7e a0 07 03 21 53 03 c7 7e ~ ..!S.Ç~
[26/05/2020 08:24:10] Written data (COM4)
[26/05/2020 08:24:15] Written data (COM4)
[26/05/2020 08:24:20] Written data (COM4)
01 42 30 03 0d 0a .B0...
[26/05/2020 08:24:26] - Close port COM4
Best regards
Piter
Kurumi's picture
That the problem. ser2net can't change baud rate after initializing and it's using 300 and not 9600 what you propose and the meter starts to use. Can you communicate without ser2net first? It might cause some problems.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Pezet032
Yep, but if I stay on 300 it should work fine, but I still doesn't have any answer for SNRM frame.
For now i don't have that possibility.
Best regards
Piter
Kurumi's picture
Your bytes are correct and the meter should reply. The problem is in the connection.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Pezet032
I read date directly from rs232 and everything works perfect!
Thanks a lot!
BR
Piter
Best regards
Piter
Kurumi's picture
Hi Piter,
Problem is that when you start to communicate with an optical probe settings are 300 7Even1. After moving from IEC to DLMS, settings are changed to 9600 8None1. ser2net can't handle this.
You can read your meter using serial port because baud rate, parity, stop bits or data bits don't change.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Pezet032
So if I connect via serial port i will start e.g. from 9600 8n1 (I know it's programable baud rate), but still it will be IEC right?
BR
Piter
Best regards
Piter
Kurumi's picture
Hi Piter,
If you are connecting using serial port your meter is communicating directly using DLMS and IEC is not needed. IEC is needed when communicating using an optical port to change the baud rate from 300 ti higher one and moving to binary mode.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Pezet032
hmm it's weird, becouse i finally got access to rs port, and now I can send IEC "/?!" to meter but on 9600 probably.
BR
Piter
Best regards
Piter
Kurumi's picture
If you are using the serial port connection starting baud rate can be anything and usually it's 9600. If you are using the optical probe (head) default starting baud rate is usually 300.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Pezet032
I know but as You said "If you are connecting using serial port your meter is communicating directly using DLMS and IEC is not needed", but it still operate on IEC, because it respond to standard IEC frame.
BR
Piter
Best regards
Piter
Kurumi's picture
Your meter is supporting both IEC 62056-21 and DLMS. If you are sending "/?!\r\n" it will start to operate with IEC 62056-21 and you need to move to mode E if you want to communicate with DLMS.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
