Firmware Update using GXDLMSDirector
6 posts / 0 new
Last post
Bhaumik
We are currently testing firmware upgrade using GXDLMSDirector and Server EXE.
Using Example server EXE while we upload the image it is crashed. So is there any update in server code to upload the image?
Do you have any Test firmware file using which we can test full functionality?
Kurumi's picture
What programming language you are using? The simple server doesn't actually update the image. It only transfers the image. You can use any image file you want to.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Bhaumik
I am using C# programming language.
Kurumi's picture
I did try to update the image and it worked without problems. What kind of problem you have?
BR;
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Bhaumik
I am using server of C programming language and updating image from GXDLMSDirector.
When I am updating image, Image is trasferred from GXDLMSDirector to server. After that server exe crashed and no further process happen.
Kurumi's picture
Are you using malloc or it is ignored?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
