I am using Sumeru verde energy meter.
I am used Gurux.DLMS.Python to read the value of energy meter.
Where I can enter high level authentication key in the code ?
Sir, My meter password is 2222222222222222 in decimal.
I am write a python main.py -S /dev/ttyUSB0 -a High -P "7E5196E2AE38E" in the terminal, its gives the error. It shown the below.
Authentication: Authentication.HIGH
ClientAddress: 0x10
File "main.py", line 69, in main
reader.readAll()
File "/home/pi/dlms/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 485, in readAll
self.initializeConnection()
File "/home/pi/dlms/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 303, in initializeConnection
self.client.parseAareResponse(reply.data)
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/GXDLMSClient.py", line 522, in parseAareResponse
self.isAuthenticationRequired = _GXAPDU.parsePDU(self.settings, self.settings.cipher, reply, None) == SourceDiagnostic.AUTHENTICATION_REQUIRED
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 641, in parsePDU
ret = _GXAPDU.parsePDU2(settings, cipher, buff, xml)
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 807, in parsePDU2
raise GXDLMSException(resultComponent, resultDiagnosticValue)
GXDLMSException: Access Error : Device reports a hardware fault.
Its gives a error(python main.py -S /dev/ttyUSB0 -a High -P """""""" )
ClientAddress: 0x10
reader.readAll()
Hi.
Hi.
You need to change the client address also.
client = GXDLMSClient(True, 0x30, 0x1, Authentication.HIGH, bytes("Password"), InterfaceType.HDLC)
Sir, I am not understand
Sir, I am not understand which python file change these setting.
I am run the main.py file.
Add parameters -a High -P "PASSWORD".
Client examples are supporting only ASCII password. If you want to use HEX, you need to hardcode it.
ClientAddress: 0x10
reader.readAll()
That is a hex string. You need to hard code it. You can try to give it as hex value:
0x22 equals " in ASCII
ClientAddress: 0x10
reader.readAll()
Can you run this with -t Verbose parameter?
Its gives this error(python
Its gives this error(python main.py -S /dev/ttyUSB0 -a High -P """""""" -t Verbose).
ClientAddress: 0x10
TX: 16:38:23 7E A0 07 03 21 93 0F 01 7E
RX: 16:38:23 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 16:38:23 7E A0 4C 03 21 10 3E 61 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 80 F4 1E 41 C2 2B EC 1D 96 AE A6 D1 6F 9A D1 27 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 50 79 7E
RX: 16:38:23 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 0F 53 7E
TX: 16:38:23 7E A0 07 03 21 53 03 C7 7E
reader.readAll()
Your client address is wrong.It should be 48 (0x30). Try to add parameter -c 48
Again its gives a error
Again its gives a error(python main.py -S /dev/ttyUSB0 -a High -P """""""" -c 48 -t Verbose).
ClientAddress: 0x30
TX: 22:36:55 7E A0 07 03 61 93 69 47 7E
RX: 22:36:56 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 22:36:56 7E A0 4C 03 61 10 58 27 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 29 0E 8D 7D 51 D3 AC 66 32 FF 4F 28 77 E3 33 13 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF FC 78 7E
RX: 22:36:56 7E A0 58 61 03 30 07 51 E6 E7 00 61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 31 32 33 34 35 36 37 38 39 30 41 42 43 44 45 46 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 02 00 00 07 93 D9 7E
TX: 22:36:56 7E A0 07 03 61 53 65 81 7E
reader.readAll()
File "/home/pi/dlms/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 306, in initializeConnection
for it in self.client.getApplicationAssociationRequest():
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/GXDLMSClient.py", line 539, in getApplicationAssociationRequest
raise ValueError("Password is invalid.")
ValueError: Password is invalid.
Hi Manish,
Hi Manish,
You need to change password to the client example. Our locale settings are different and the password is not recognized for ASCII string.
