The event can be basically anything, but in your case meter is sending push object list as a first parameter.
This makes it possible to handle this.
You can use ParsePushObjects method to parse received data.
You can check Gurux.DLMS.Push.Listener.Example.Net for more info. Just change interface from WRAPPER to HDLC.
Thanks for the quick reply.
We have generated this event from the example server. At present we don't know in that format meter is sending the event.
I have read Event Status Word from GXDLMSDirector. In that bitstring response received, Now I want to check which event is occured. So Is there any specific parsing for events in Gurux code respective to IS15959-2.
We released yesterday a new version from GXDLMSDirector get it. Then there are new manufacturer settings for India standard. Update new manufacturer settings and then read the association view again.
Yo can now see possible values as bit string and checked list when you select Event Status Word 1 (ESW-1).
List<KeyValuePair<GXDLMSObject, int>> objects = client.ParsePushObjects((List<object>)tmp[0]);
Is OBIS code 0.0.94.91.18.255?
Yes, OBIS code is 0.0.94.91
Yes, OBIS code is 0.0.94.91.18.255
We'll update bit string values and release them on Monday.
Thanks for the support.
Let me know once you release it today.
Any update on release?
Tests are almost finished.
Thank you so much for the
Thank you so much for the release.
Now able to check properly for the occurred events.
