Trying to get a reading of a landis+gyr e650
12 posts / 0 new
Last post
ilhan
I have tried to read out the Landys-Gyr E650, finding out it's a DLMS meter
I'm using the following hardware:
- Raspberry Pi 3B
- A RS485 cable connected to the meter, installed by the network operator.
- the RS485 cable connected through ch341-uart converter through usb on the raspberry Pi
Having cloned https://github.com/gurux/gurux.dlms.python and installed all the dependencies, I have tried to get it working through, but so far I get the following outputs:
~/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python $ python main.py -S /dev/ttyUSB0
ClientAddress: 0x10
RX: 17:13:41
What else could I try ?
Kurumi's picture
I'm not quite sure what converter you have, but In my mind, ch341 UART is for 5V/3.3V.
RS485 is using 12V.
Check is your converter working anymore and buy a converter for RS485.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ilhan
Thanks for you answers, yes the ch341 is for 5V, what product do you recommend.
The DSO has placed an RS485 cable which is just a D+ and D- Cable, I placed the Red in the D+ and Green in D-, I currently get the following output:
ClientAddress: 0x10
RX: 16:26:33
File "main.py", line 80, in main
reader.readAll()
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 423, in readAll
self.initializeConnection()
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 235, in initializeConnection
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 91, in readDLMSPacket
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 142, in readDLMSPacket2
raise e
TimeoutException: Failed to receive reply from the device in given time.
- Besides the converter could it also be a default password that it's missing as it's and industrial meter ?
Best, Ilhan
Kurumi's picture
Hi Ilhan,
If you are using RS-232 converter (ch341), the connection is newer work. You need an RS-485 converter.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ilhan
The converter is sold as RS485, it's this one https://www.reichelt.nl/framboos-pi-usb-rs485-interface-rs485-ch340c-rpi...
Should this one work ? Or not because it's 5V
Kurumi's picture
We have not used this model. You need to try. Note that there are no drivers for Windows 10.
Let me know if you have any problems.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ilhan
We are running it on a raspberry Pi 3, which is linux and the ch340 is in the linux directory, so no drivers are needed.
What device would you recommend for this?
Kurumi's picture
We haven't try with this RS-485 converter. I have to say that it's cheap.
We have used example Exsys converters.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ilhan
I'm looking at the manual of Exsys rs485-usb converter: https://cdn-reichelt.de/documents/datenblatt/E910/EXSYS_EX1309T_MN_ENG.pdf
The RS-485 connection the DSO placed was orignally in a rj-11 connection, I stripped it and only the green and red cable are left. Which connection do I put them in (see attached picture) ?
Image:
Kurumi's picture
If you have only two wires use the upper (default). Lower is for four wires.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
ilhan
Hi again,
I got the exsys cable in and this will I'll head up to solar panel meter to install it. I'm using the https://github.com/Gurux/Gurux.DLMS.Python/tree/master/Gurux.DLMS.Client... to test the connection and my usual testing command is : `python main.py -S /dev/ttyUSB0`
If you would want to set a different baudrate, how would you do this using the Example Python Client ?
Kurumi's picture
At the moment the best way to set serial port settings is modifying main.py.
We'll improve the example client so you can give serial port settings as a parameter.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
