I'm trying to create a server tcp/udp using Gurux.DLMS.Meter.Listener example; when my meter connects to server correctly, it raises OnClientConnected() event but here I can't read the push frame meter sends to the server.
How can I read this first frame with GXNet before GXDLMSReader.ReadAll()?
Check Gurux.DLMS.Push.Listener.Example.Net if you want to receive push messages.
Gurux.DLMS.Meter.Listener is for connections where meter makes connection to the server.
Thanks for the response; My problem is my meter wake up and send push to my server but it raises OnClientConnected() event and I cannot read this first frame.
What method I need to use to read this frame?
Can you post data that meter sends here?
