use other calendar than Gregorian
Project:
Gurux.Net
hi, thank you for your hardworking
I want to use Persian Calendar and Persian date instead of Gregorian date. In GxCommon there is method
private static void SetDateTime(GXDLMSSettings settings, GXByteBuffer buff, object value)
that change Gregorian date to 12 byte Dlms format. I want to know if there is simple workaround to use Persian Date in this function and other related parts.
I want to update my dlms code according your updates and don't want to change this code personally.
thank you in advance.
Status:
Active
Priority:
Critical
Category:
Support request
Component:
Code
Reporter:
ali_bahal
Created:
Wed, 11/27/2019 - 16:35
Updated:
