Hi. I am trying to read a meter using tcp / ip using the gurux_dlms and gurux_net libraries in python2.7. Python 2.7 is the version that I have available in my system. But, when I run my script it shows me the following error.
File "readRMSMeter.py", line 40, in <module>
client.authentication = Authentication["LOW"]
TypeError: 'type' object has no attribute '__getitem__'
I am assigning the necessary information for the connection directly, as follows
from gurux_common.enums import TraceLevel
from gurux_dlms.secure import GXDLMSSecureClient
from gurux_common.io import Parity, StopBits
from gurux_common import ReceiveParameters, TimeoutException
from gurux_dlms import GXByteBuffer, GXReplyData, GXDLMSTranslator, GXDLMSException
from gurux_dlms.enums import InterfaceType, ObjectType, Authentication, DataType, Security
from gurux_dlms.objects import GXDLMSObject, GXDLMSRegister, GXDLMSDemandRegister, GXDLMSProfileGeneric, GXDLMSObjectCollection
from gurux_net.enums import NetworkType
from gurux_net import GXNet
Can someone help me please to identify why this error happens, since in GXDLMSClient and Authentication, I don't see this '__getitem__' parameter or method.
Thanks for your collaboration, I really appreciate it. The problem was corrected, but I can't connect yet with the meter. My script work in python 3.5, so I try again with the the example given in the gurux github in python2.7. And I'm giving the follow parameters:
Authentication: 1
ClientAddress: 0x1
ServerAddress: 0x91
File "main.py", line 80, in main
reader.readAll()
File "/home/dev/rms/GXDLMSReader.py", line 423, in readAll
self.initializeConnection()
File "/home/dev/rms/GXDLMSReader.py", line 241, in initializeConnection
self.client.parseAareResponse(reply.data)
File "/home/dev/lib/python2.7/site-packages/gurux_dlms/GXDLMSClient.py", line 522, in parseAareResponse
self.isAuthenticationRequired = _GXAPDU.parsePDU(self.settings, self.settings.cipher, reply, None) == SourceDiagnostic.AUTHENTICATION_REQUIRED
File "/home/dev/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 641, in parsePDU
ret = _GXAPDU.parsePDU2(settings, cipher, buff, xml)
File "/home/dev/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 792, in parsePDU2
_GXAPDU.updateAuthentication(settings, buff)
File "/home/dev/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 959, in updateAuthentication
settings.authentication = Authentication(ch)
TypeError: object() takes no parameters
Thank you very much for your help. The errors that I had were fixed. Im working with two linux distros, openSuSE Tumbleweed and an Openwrt, in the last is where I will leave it running at the end. Again Thanks.
I belive that reason for this is this line:
Try to use this:
client.authentication = Authentication.LOW
$> python main.py -h 127.0.0.1 -p 8082 -c 1 -s 145 -P ABCDEFGH -a Low -i
and show me this error:
Authentication: 1
ClientAddress: 0x1
ServerAddress: 0x91
reader.readAll()
Can help me, please?
Are you running this on Linux? What is your distro?
Can you modify the package? Change this line from :GXAPU.py:
to:
settings.authentication = ch
We'll change this and publish a new version on Monday.
We'll test this with OpenSuSE also on Monday.
A new version (1.0.36) is released where this is fixed.
