Application Association request with authentication level high
2 posts / 0 new
Last post
Bhaumik
I trying to connect meter (IS15959) with the authentication level as high.
Using GXDLMSDirector I can connect meter properly. But when I am trying from our test application it is not able to connect and gives the following response :
7EA00F61037410D7E6E700D8010683377E
Can you please check and revert back asap.
I have set all required parameters to connect the meter with authentication high.
Do I need to set any other configuration?
Kurumi's picture
Can you post all the messages? One of your settings is wrong.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
