By ambimat, 7 October, 2019 Forums Gurux.DLMS Hello, Can anyone suggest what data points are covered under what Class ID? Thanks Ambimat. Hi, Hi, I'm sorry, but it's impossible to answer your question. DLMS standard defines available class IDs. Meter manufacturers can select from those classes. You need to read data from the meter and check what OBIS code and class ID manufacturer has used. BR, Mikko Okay. Okay. Thank you for the response. Ambimat. Log in or register to post comments
Okay.
Okay.
Ambimat.
