I am able to read EDMI MK 6 meter with .net code and read the parameter with Low authentication.
When I tried to read generic profile 1.0.94.91.4.255 with read by range and row it does n't work. So I tried with Read(it,2) and read(it,3) as suggested.
with data index =2, I got the result as {1, frequency}, {1, Voltage} and so on..
But in case of 3, I get list of objects. and value column in it return null.
I believe that your meter is using attribute 0.
It means that your meter is saving all values from the register to one cell and there are there in array.
You need to access data selecting the cell and then get wanted data using array index.
Hi Sachin,
Hi Sachin,
Mikk
Thanks for your reply.. Can you provide code sample for same.
Sachin Ambre
When you have data in to the buffer you can access it something like this:
object[] row = pg.Buffer[0];
//Update correct cell index.
object[] cell = (object[]) row[1];
object[] value = cell[0];
