I have already set correct settings and I am able to connect and read with authentication and encryption. But, the problem comes when I add General block transfer in the services. After that when I connect it shows connected. But when I read clock object it sends plain text to meter instead of encrypted. But, if I remove the General block transfer service, it sends ciphered text and gets the correct response.
I just verify this and you are right. We have broken this at some point. We'll fix this ASAP.
Testing will take a few days, but we'll try to release the next version during this week.
You need to set correct settings fo the "Secured Connections" tab when you create a new device.
You need to change following settings:
Set Security to AuthenticationEncryption.
Set system title, authentication key, and block cipher key.
Hi, Thanks Mikko Prabhat
Thanks Mikko
Prabhat
Hi Prabhat,
Hi Prabhat,
We have released a new version from GXDLMSDirector today where this is fixed.
