memory corrupted by incorrect memcpy() usage
Project:
gurux.dlms.cpp
see PR #23 for fix. https://github.com/Gurux/Gurux.DLMS.cpp/pull/23
memcpy() is called with the address of a pointer, not the pointer value.
Status:
Closed (fixed)
Priority:
Major
Category:
Bug report
Component:
Code
Reporter:
seanscoggins
Created:
Thu, 08/22/2019 - 23:51
Updated:
Fri, 08/23/2019 - 14:52
Comments
Kurumi's picture
You are right on this. We'll start tests and release a new version today. Your name is added to the credits. but we can't merge your pull in GitHub, because we have own private repo where code is push to the GitHub.
Thank you very much from this info.
Administrator's picture
Status: Active » Closed (fixed)
