By motorhead, 12 August, 2019 Forums Gurux DLMS for Java Hi im trying to read a meter with your library in java platform in your example there's a method "readDLMSPacket" i cant find a source for it would you please explain me how to do? Image Hi, Hi, You should check gurux.dlms.client.example.java. You can get it from the GitHub: https://github.com/Gurux/Gurux.DLMS.java BR, Mikko Hi Hi i checked all the examples but i didnt find this method/class Whats it's function? Hi, Hi, https://github.com/Gurux/gurux.dlms.java/blob/master/gurux.dlms.client… Check rows 157 and 200. BR, Mikko Log in or register to post comments
