I am able to read tamper event codes from OBIS = 0.0.96.11.e.255 IC = 1, values of e range from 0 to 6). I want to read the detailed event history (logs) for tampered events i.e - tamper logs using (OBIS = 0.0.99.98.e.255 IC = 7, values of e range from 0 to 6). But I am unable to receive the proper response. I am referring IS 15959-2011. Please help me in parsing tamper records along with logs.
But as per the IS 15959-2011 doc it should display the parameters such as date, time, current ,energy, etc. but here no information for log is visible.
Hello Mikko,
Hello Mikko,
Any help on this ?
Sarbjit Singh
Hi Sarbjit,
Hi Sarbjit,
What kind of response you are getting? Is the problem that there is a list of values?
Mikko,
Mikko,
I am getting the following response for the OBIS codes of event log:
Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.0.255 ---- Ch. 0 Event log 1
Entries: 0/80
-------- Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.1.255 ---- Ch. 0 Event log 2
Entries: 0/80
-------- Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.2.255 ---- Ch. 0 Event log 3
Entries: 48/64
11/07/14 11:03:00:000 | 101 |
-------- Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.3.255 ---- Ch. 0 Event log 4
Entries: 0/16
-------- Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.4.255 ---- Ch. 0 Event log 5
Entries: 0/40
-------- Reading Hist GXDLMSProfileGeneric ---- 0.0.99.98.5.255 ---- Ch. 0 Event log 6
Entries: 0/1
Sarbjit Singh
There is no data from 0.0.96.11.e.255 in your log. Try to change authentication level to higher or then it's not implemented for the meter.
