By vslab, 19 July, 2019 Forums DLMSDirector GXDLMSDirector 8.1.1906.1301 Log created 16:21:17 16:21:19 Initializing serial connection. 16:21:20 IEC Sending:/?!<CR><LF> 16:21:21 HDLC received: /ISK5\2ME371-2105<CR><LF> 16:21:21 BaudRate is : 9600 16:21:21 Moving to mode E. 06 32 35 32 0D 0A 16:21:25 Send SNRM request. 7E A0 08 02 23 C9 93 E4 43 7E 16:21:25 7E A0 1F C9 02 23 73 B4 96 81 80 12 05 01 7E 06 01 7E 07 04 00 00 00 01 08 04 00 00 00 01 5F 75 7E 16:21:25 Parsing UA reply succeeded. 16:21:25 Send AARQ request. 7E A0 2C 02 23 C9 10 F6 B8 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 16:21:25 7E A0 39 C9 02 23 30 22 BD E6 E7 00 61 2A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0C BE 11 04 0F 08 01 00 06 5F 1F 04 00 00 1C 1D 04 00 00 07 D5 26 7E 16:21:25 Disconnect request 16:21:25 7E A0 1F C9 02 23 73 B4 96 81 80 12 05 01 7E 06 01 7E 07 04 00 00 00 01 08 04 00 00 00 01 5F 75 7E Gurux.DLMS.GXDLMSException: Connection is permanently rejected. Authentication mechanism name is required. в GXDLMSDirector.GXDLMSDevice.InitializeConnection() в GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters) help Image connected to these settings. connected to these settings. read-only. Image Hi, Hi, Error message describes it: Connection is permanently rejected. Authentication mechanism name is required. You can connect only using low or High-Level authentication. The connection is not allowed without authentication. BR, Mikko Log in or register to post comments
