how to run python frmaework in windows?
77 posts / 0 new
Last post
Ram
Im running my python library but im getting error like this
PFA
Ram
The code which is available in github is all about socket programming for gurux dlms python framework.
I want to know whether there is any source code for serial port programming for gurux dlms python framework
Kurumi's picture
I believe that your python version is wrong. Try to run this as "python3 main.py".
Support for the serial port is added later.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
okay by what time serial port code will be added
Kurumi's picture
It's in the test phase. We'll release it in August.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
After compiling main file we are getting like this. what we need to do next. For serial port what we need to give as command line arguments.
thanks
Image:
Kurumi's picture
Python does not support serial port at the moment.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
U said that python framework for serial port will be released in august.
By what date it will be release?
Kurumi's picture
We are testing it at the moment. We'll try to release it as soon as possible. I can't give any exact date.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
I'm trying to connect via serial port but im getting errors.
why, it wont work for serial port now??
Kurumi's picture
Serial port implementation for Python is not released yet. Only TCP/IP connection is released.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
Is python code ready for serial port?
Is it ready or still work in progress?
Kurumi's picture
We released the first version last Friday. You can communicate over the serial port, but we are making a few changes so communication is possible using an optical head (probe). This version is released during this week.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
okay thanks Mikko
Ram
Recently you uploaded code for serial port communication.
how to run that Gurux.Serial.python-master?
I mean which file we have to run.
Thanks waiting for ur fast reply
Kurumi's picture
You don't run gurux-serial. You run it like this:
python Gurux.DLMS.Client.Example.python -s "SERIAL_PORT_TO_USE"
You need to update the serial port to correct one. We'll make a video tomorrow.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
we run the code like as u said but im getting this error.
please check it once.
And when your going to upload a video of this?
Image:
Kurumi's picture
HI,
run this:
pip install --upgrade gurux-serial
pip install --upgrade gurux-dlms
We are working with the video at the moment.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
Hi Mikko
Even though we gave correct port number we are getting this error.
Image:
Kurumi's picture
You need to change "UPDATE CORRECT PORT" to "COM1" or "Com3" in the example.py.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Kurumi's picture
You should check this video.
https://youtu.be/OcmYvcsgjz4
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
we run the code like as u explain in the video but we are getting like this.
we checked from meter side also but we are able to read the values in GXDLMSDIRECTOR successfully
Image:
Kurumi's picture
What serial port you are using? Is that connected to the USB port? Can you give link to the manufacturer page?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
how can we give a link to manufacturer page?
please can u explain?
Kurumi's picture
What is the model and manufacturer of your serial port?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
I'm using RS232 serial port and DB9 pin
Kurumi's picture
Yes, but I need information from the manufacturer and model of the serial port.
Is that integrated to the PC or is it USB port?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
It is a TriVector meter and I'm using USB port to connect to my PC.
Kurumi's picture
What is the manufacturer and model of the USB port?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
pafcioz
I have the same error:
My output:
Available ports:
File "test.py", line 97, in <module>
sampleclient()
File "test.py", line 13, in __init__
print(str(GXSerial.getPortNames()))
File "C:\Python27\lib\site-packages\gurux_serial\GXSerial.py", line 148, in getPortNames
return cls.__initialize().getPortNames()
File "C:\Python27\lib\site-packages\gurux_serial\_handlers\GXWindowsHandler.py", line 206, in getPortNames
raise Exception('Failed to get port names: {!r}'.format(ctypes.WinError(ret)))
Exception: Failed to get port names: WindowsError(2, 'The system cannot find the file specified.')
I'm running the example code from 'github's readme' page.
I'm using the usb to rs232 converter (based on ftdi chip) (it's id is FTDIBUS\\VID_0403+PID_6001+A5057FY9A\\0000)
Regards
pafcioz
Ram
I don't know exactly maybe try with python 3
Kurumi's picture
Hi pafcioz,
Please, if you have a new question, create a new topic.
This is not the same error. What version from Windows you are using? We might know the reason for this.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Kurumi's picture
There is a new version (1.0.12) from gurux-serial where ASCII and UNICODE support is improved.
Let me know if you have problems.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
While running the code we are getting the error as below.
please check the picture what i send
Image:
Ram
After reading it is successfully disconnected but still it is in waiting stage and it is not coming back to console(not terminating).
please check the picture what i send.
Image:
Kurumi's picture
Please, don't send pics. It's hard to get data from there. Paste received bytes and I'll check it. Don't paste all data, just failed one and.
updateAuthenticationMechanismName is fixed and a new version (1.0.17) is released. It'll fix the first image issue.
Can you run the app with -t Verbose parameter and send DisconnectRequest data. I need to check why meter is no reply.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
We tried with updated code but we are getting the same error.
Kurumi's picture
Did you run pip install --upgrade gurux-dlms? jointIsoCtt is fixed and it succeeds.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
pafcioz
In my case upgrading the library to 1.0.12 helped.
Ram
Yes that problem is sorted out now.
Only problem is now after reading data it is showing disconnected request then the console is not coming back.
Kurumi's picture
Can you run the app with "-t Verbose" parameter and send DisconnectRequest data. I need to check why the meter is no reply.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
Hi Mikko
Like U said in the video if we are running the code we are getting all values.
But we want individual values like if we send particular obs code we have to get that particular values.
We tried to run with -g while running but we are facing issues like
C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python>main.py -S COM3 -g \"0.0.1.0.0.255:1\"
File "C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python\main.py", line 53, in main
ret = settings.getParameters(args)
File "C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python\GXSettings.py", line 170, in getParameters
raise ValueError("Invalid Logical name or attribute index.")
ValueError: Invalid Logical name or attribute index.
Kurumi's picture
Get the latest version from GitHub. This is fixed.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
We are getting values for the selected objects, But if we want all attributes of a single OBS code then how to do it.
Ram.
Kurumi's picture
You need to loop all object attributes and read them all. Check client example it does what you require.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
We didn't find anything in client example regarding loop of object attributes. Can you tell the exact file location where it is.
Thanks and Regards,
Ram.
Ram
How to get all the OBIS code that all present in the meter along with its attributes??
Like:
<Data Obis="0.0.1.0.0.255" IC="8" MethodID="0" Action="Get" Attributes="1,2" Version="0" />
Kurumi's picture
Hi Ram,
Check GetReadOut method. It reads association view from the meter and then reads all attributes for each object.
Association view described what kind of functionality meter can offer.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
Like,if I gave something OBIS-0.0.1.0.0.255 I want to get all the values at a time.
Is it possible?If possible How?
Kurumi's picture
No. You can't get all values reading one OBIS code. You need to read each object separately.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Ram
I want to get all the values for given one specific obis code and u said that there is a for loop in client example where is that for loop in our code? I mean in which file/folder.
Pages
