I would like to report a issue with Profile Generic attribute Capture Objects edit/write new object that causes write of capture objects in wrong order than it is displayed in user interface.
Reproducing steps:
1. Read Capture Objects of object Profile Generic (General Display Readout) shown in Profile Generic attribute Capture Objects after read.PNG and Profile Generic attribute Capture Objects read log.txt
2. Edit first Capture Object to new value in example changed {Data, 1.0.0.9.1.255, 2} with {Clock, 0.0.1.0.0.255,2} shown in Profile Generic attribute Capture Objects edit first object and change to new one.PNG and Profile Generic attribute Capture Objects after edit and before write.PNG.
3. Click on Write and application now shows that edited first element is now last element of Capture Objects shown in Profile Generic attribute Capture Objects after write.PNG and Profile Generic attribute Capture Objects write log.txt
From last write log it can be seen that application changes the order of Capture Objects in SET service PDU, and after GET service read update it than shows this new order of Capture Objects. Editing existing elements should retain order of Capture Objects the same as the user is observing it in User Interface before write, because order in Profile Generic Capture Objects is usually important.
if you need more info please contact me.
Best Regards,
Vanja
