I would like to report the issue with Limiter class attribute Monitored Value write.
In Attached log file when read this attribute returns correctly:
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<Structure Qty="03" >
<UInt16 Value="0005" />
<!--1.0.1.24.0.255-->
<OctetString Value="0100011800FF" />
<Int8 Value="02" />
</Structure>
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
But after changing the monitored value and executing write GXDLMSDirector sends the data with wrong type for Monitored Value structure element Attribute Index instead of Int8 it sends UInt8 (In DLMS Blue Book it is stated that this element is of type Integer or Int8):
<SetRequest>
<SetRequestNormal>
<AttributeDescriptor>
<!--Limiter-->
<ClassId Value="0047" />
<!--0.0.17.0.0.255-->
<InstanceId Value="0000110000FF" />
<AttributeId Value="02" />
</AttributeDescriptor>
<Value>
<Int16 Value="0005" />
<!--1.0.15.24.0.255-->
<OctetString Value="01000F1800FF" />
<UInt8 Value="02" />
</Structure>
</Value>
</SetRequestNormal>
</SetRequest>
If you need more info please contact me.
Best regards,
Vanja Ninkovic
MIGMA s.p.
You are right. Thank you from this info. This is fixed and we have started tests. We'll release new version tomorrow where this is fixed.
Thanks for prompt response and action, GXDLMSDirector is really good application and I like using it.
I have few more issues and I will post them soon for review.
