I'm trying to access data from a ZIV counter with DLM-Cosem procolo, there's no way to get it. I always get communication error ...
Can it be some kind of password? The probe if it blinks ...
Is your Probe connected directly to your PC or is there USB to the serial port converter and then the probe is connected to the serial port? What settings you are using?
Connect to ZIV counter
Directly I use the PC with a
Directly I use the PC with a probe to USB, without any type of converter. The configuration is without any password, COM4, 96008n1
Try to change "Start protocol" from DLMS to IEC.
