I am running "GuruxDLMSServerExample" as a server and DLMSDirector as a client for reading data.
I am able to read clock object from that server but unable to read register object from that server.
I have connect DLMSDirector to "GuruxDLMSServerExample" with "None" authentication.
I am fetching below mentioned register object-
Ch. 0 Sum Li Active power+ (QI+QIV) Inst. value
1.0.1.7.0.255
This is last error messages
2 Value Access Error : Device reports a undefined object.
3 Scaler and Unit Access Error : Device reports a undefined object.
Kindly suggest me. What will the access credential?
1.0.1.7.0.255 is not found from the meter. You need to add it to the device and association view.
When you read association view again (Select "Refresh" from "File" menu) you will see your register.
What programming language you are using? Try to skip all your changes and start from the begin.
If you are using ANSI C, make sure that you are initializing COSEM objects using a correct enum value.
How to access register object of "GuruxDLMSServerExample" meter
I am unable to get
I am unable to get association view. It showing the error like-
"GetObjects failed. Failed to receive reply from the device in given time"
