I am trying to determine the scaler and unit of load profile column of a Actaris SL7000 meter.
I am struggling at the moment.
When reading attribute 3 of the individual column register(I.E 1.1.1.29.0.255) I get Access Denied.
I have tried using other registers/extender to determine the load profile scaler and unit but the values is not the same when comparing the readings to what is produced with Ace Pilot.
There are some problems with SL7000. It doesn't implement all the attributes, etc. You need LogicalDevice SL761 document. You should ask that from the vendor.
Actaris SL7000 Load Profile Scaler Unit
