By dkp, 24 September, 2018 Forums DLMSDirector Hi I am a college student. I have a question. There is a problem with using DLMSDirector. First, meter manufacturer to communicate is Namjun(G-Type). The meter supports RS485(RJ11) communications. So I connected to the meter using a USB-RS485(RJ11) converter. Then, they created a manufacturer through 'Tools-Manufacters-New' from DLMSDirector. Flag ID : NJC Name : Namjun Web Address : http://namjun.com/ko/ Standard : DLMS Start protocal : DLMS But I don't know what 'Client Address' means. Also Server Address - Phycial Address, Logical Address too. I really don't know. Thank you. Image Device settings Hi, You need to ask client and server address from the manufacturer, but you can use with these: client address: 10 Server address: 1 Select also "Use logical name referencing". BR, Mikko Log in or register to post comments
Device settings
client address: 10
Server address: 1
