I have an ACE6000 meter and I read it without problems with the default configuration, but suddenly I started answering "Connection is permanently rejected. Authentication failure", I already tried with another meter and it does respond. Does anyone know how to reset the meter configuration to the default?
Problem with ACE6000
You need a password if you want to do it programmatically. You should ask this info from the meter vendor.
Note! you will lose all the readings if you reset the meter.
