I am trying to connecto to an Elster A1052+ via USB probe with no success, I have tried lots of configuration.. According to its specifications its maux baud rate is 2400 , and its IRDA port is IEC 62056-61 compliant..
I always receive "Failed to receive reply from the device in given time.";
If someone has any hints, it will be highly appreciated
unable to connecto to Elster A1052+
What server address you are using? Try to select IEC as start protocol. Don't change anything. Just select IEC and try.
