REGARDING ATTRIBUTE INDEX 1 OF EVERY OBIS
51 posts / 0 new
Last post
princetripathi
Not able to read the attribute index 1 of any OBIS in XML or PDU form so not able to get that what is getting passed to the meter in reagard to Logical device name
Kurumi's picture
Can you connect with GXDLMSDirector?
Check your client and server addresses.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Thanks Mikko, Got that problem.
can you tell me about what is AARQ protocol version
prince tripathi
Kurumi's picture
DLMS version is 6. protocol-version is is not send as a default. You can set it using ProtocolVersion property of GXDLMSClient.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Thanks sir,
Got it how to set protocol version .
prince tripathi
princetripathi
Hello mike,
Can I get your help
Need to ask that whats is AA release??
prince tripathi
Kurumi's picture
When the client is closing connection it calls AA Release. In this phase Connection to the AA is released.
If client is using example WRAPPER and Release is not called, next client can make a connection after inactivity time is past. In HDLC framing Disconnect calls also Release.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Thank you, Mike for getting my doubt clear.
prince tripathi
princetripathi
Okay. I am using Single byte addressing there are no limitation to it further ?
prince tripathi
princetripathi
Hi Mike,
Can you help me what is the diffrence between single byte address and double byte address in DLMS
Is there any issue if we use single byte address instead of double byte in IS 15959 part 2
prince tripathi
princetripathi
Okay, I am using single byte addressing is there in any limitation to it further??
prince tripathi
Kurumi's picture
If you want to pass DLMS Certificate tests you must support also two-byte and four-byte addressing.
If you are using serial number you need to add support for four-byte addressing.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Okay thank you mike,
I am looking toward 4 byte addressing
prince tripathi
Kurumi's picture
If you are using two-byte addressing you can have more logical devices. In DLMS Certificates single and double-byte addressing are tested. In general, there are no differences are you using one or two byte-addressing.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Hello mike,
I want to know that is there any specific OBIS code for PUSH_setup or not.I am not able to find the push obis
prince tripathi
Kurumi's picture
Yes there are. Example 0.1.25.9.0.255
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Hello miko,
Thanks for helping with push,
I want to know that when my tamper is occured my ESW status word shows the status and the pushed
. How can we push the instantaneous parameter through push is it necessary??
prince tripathi
Kurumi's picture
Select "Push Setup" -object in GXDLMSDirector. Then select Objects -tab. Add object what you want to send to the list. Set also Attribute index. Data index can be zero.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
If i want to send data or send any object by push then I have to add the object and then hit push from Director am I getting you right mike?
prince tripathi
Kurumi's picture
Yes. Objects what are added to Push Object List are sent when Push is triggered. Push can be triggered example schedule or a user can press Push -button to activate the push event.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Hi mike,
While adding the object mannually when I click on the object it show a popup block which has 2 blocks
1) Target
2) index
In target i have to give push obis or destination address or port number??
prince tripathi
Kurumi's picture
If your meter supports sending Push objects using TCP/IP you will give this information to Destination field. This is usually something like "IpAddress:PortNumber".
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Thanks mike for all your help.
Can you tell me how to generate tag for encryption method in HiGMAC security ??
prince tripathi
princetripathi
*tag for authentication encryption
prince tripathi
Kurumi's picture
If you are using GMAC you need to encrypt the message. You don't just add a tag.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
i have completed the encryption part .
a
Actually I am making US association for that I am not getting how to add a tag for autentication encryption in HiGMAC
prince tripathi
Kurumi's picture
Change authentication level to GMac. It'll do everything for you.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Hi mike,
Thanks for helping and solving issues
Can you let me know that can we give 2 byte and 4 byte addressing in GURUX and How?
prince tripathi
Kurumi's picture
On GXDLMSDirector select "Advanced" tab and change "Server address size" from 1 to 2 or 4.
In source code use GXDLMSClient.GetServerAddress method.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Done thanks mike,
I am facing problem in security mechanism 2 (HLS) -Indian standard
*Do we have to send encrypted data in HLS
*How to send challenge in HLS
*What is secret key in HLS
so can You explain mechanism 2 indian standard
prince tripathi
Kurumi's picture
Gurux component is supporting HLS. Set authentication to High and set correct password.
Everything is done automatically for you.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Got it sir thanks for the help.
Do have idea about Pre established association ?
prince tripathi
Kurumi's picture
If you want to use pre-established association you need to set block cipher key, authentication key, client system title and server system title for client and meter. Select "Secured connections" from GXDLMSDirector device settings.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Hi mike,
Just a basic query. Wanted to know that if During Firmware upgrade when the image file is transfered successfully the CALIBRATION data (like voltage,current,kWh,kVh etc) need to get STORED or not because if this data is turning into NULL (i.e 0 like 00.00 V etc) so not sure that is it necessary to save that calibrated data or NOT .
prince tripathi
Kurumi's picture
Updating firmware doesn't reset the values.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
While making US association we use security AUTHENTICATION & ENCRYPTION so how do we generate the AUTHENTICATION tag in US ??
prince tripathi
Kurumi's picture
Authentication key and Block cipher key must be the same in client and the meter or encrypt will fail.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
The authentication and block chiper key is same in client and ,meter but still association is giving error authentication tag is wrong while performming test
prince tripathi
Kurumi's picture
Have you set client system title and Security level?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Yes, Client system title is set and Security level is HIGH LEVEL security
prince tripathi
Kurumi's picture
Can you post the log from send and reply? Don't send anything else.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Hi Mike,
Need your help regarding one subset of DLMS it says. AE.INVOCATION ID present but CLIENT USER IDENTIFICATION NOT PRESENT
prince tripathi
princetripathi
Want to know that what is Client user identification and in THIS LOGs where it is present ??
7E A0 9B 00 02 04 01 41 10 B0 CA E6 E6 00 60 81 89 A1 09 06 07 60 85 74 05 08 01 03 A2 03 04 01 44 A3 03 04 01 44 A4 03 02 01 00 A5 03 02 01 00 A6 0A 04 08 43 54 54 30 30 30 30 30 A7 03 04 01 44 A8 03 02 01 00 A9 03 02 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 41 32 42 33 43 34 44 BE 34 04 32 21 30 30 44 8E EE F7 D7 FD 87 5A 07 1C CB A5 48 26 BE 9D DB 4B 5B D7 1E C8 9E 6D 16 DB 2C 40 BD 43 70 37 96 F4 E2 B2 55 23 9E EE 3F 83 51 28 56 DF BB CC E9 7E
prince tripathi
Kurumi's picture
Your data is not correct. CalledAPTitle is system title and it's always 8 bytes long.
UserId is AEInvocationId
<AssociationRequest>
<CalledAPTitle Value="44" />
<CalledAEQualifier Value="44" />
<CalledAPInvocationId Value="00" />
<CalledAEInvocationId Value="00" />
<CallingAPTitle Value="4354543030303030" />
<RespondingAeInvocationId Value="44" />
<CallingApInvocationId Value="00" />
<CallingAEInvocationId Value="01" />
<MechanismName Value="Low" />
<CallingAuthentication Value="3141324233433444" />
<!--Decrypted data:
Invocation Counter: 1150217975
<!--Error: Failed to decrypt data.-->
<glo_InitiateRequest Value="30448EEEF7D7FD875A071CCBA54826BE9DDB4B5BD71EC89E6D16DB2C40BD43703796F4E2B255239EEE3F83512856DFBB" />
</AssociationRequest>
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Hi mikko,
Yes the DATA is actually the hit is from one of the test case in CTT test.
Want to know about client user identification
prince tripathi
Kurumi's picture
Client user identification is described on the standard. It's number that client application sends.
Meter check is this client ID supported or not.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Thanks Mikko, it really helped.
prince tripathi
princetripathi
Hi mike,
When I am trying to do image transfer from the mannual mode after selecting the mannual way for image transfer.The Verify method select or access is not getting enable even after giving the access to all the method of the FOTA. and image transfer I have highlight that option in the image
Image:
prince tripathi
Kurumi's picture
Verify btn is disabled if the image is already verified. Status in your image is "Verification Succeeded.
Now you can only update a new image or activate it,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
princetripathi
Hello mike,
Even if the verification successful is not present the image is going for activation and that verify button is not getting enable even if the all the method have their desired access
prince tripathi
Kurumi's picture
What the status is?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
