Gurux.Net
Log in to post new content in the forum.
Topic / Topic starter | Replies |
Last post![]() |
Sticky:
Introducing GXNet by Gurux Ltd » Tue, 11/24/2009 - 09:08 |
0 |
by Gurux Ltd Tue, 10/19/2010 - 12:51 |
Addressing by hassin Ayaz » Sun, 12/24/2017 - 08:37 |
4 |
by hassin Ayaz Sun, 04/22/2018 - 10:18 |
Getting Invalid Client exception whiling reading meter over GPRS by erdeepakcs » Tue, 03/27/2018 - 14:52 |
0 |
by erdeepakcs Tue, 03/27/2018 - 14:52 |
help with General GLO Cipher by Swappage » Wed, 01/24/2018 - 16:33 |
8 |
by Swappage Tue, 01/30/2018 - 11:34 |
Sending sepecific reading request (e.g. clock rate, voltage) To Meter or DCU by nafeezabrar » Tue, 01/09/2018 - 08:19 |
3 |
by kurumi Wed, 01/17/2018 - 08:24 |
GXNet.Open() causes randomly SocketExceptions by Stier » Tue, 11/07/2017 - 18:39 |
6 |
by kurumi Mon, 12/18/2017 - 11:16 |
Connect multiple meter in multi threaded environment by Stier » Thu, 03/27/2014 - 14:35 |
14 |
by SZLMCL Mon, 09/18/2017 - 16:28 |
Gurux Listen Service Issue by keenangeorge » Sat, 07/29/2017 - 18:34 |
3 |
by kurumi Mon, 08/28/2017 - 12:40 |
Is Gurux java code supported PLC communication by sree.sridharp » Fri, 07/07/2017 - 13:55 |
1 |
by kurumi Mon, 07/10/2017 - 14:03 |
Read password on SL7000 by cgonzalezb » Tue, 07/04/2017 - 18:02 |
1 |
by kurumi Wed, 07/05/2017 - 16:33 |
Read profile generic data from SL7000 by SZLMCL » Fri, 03/24/2017 - 16:49 |
11 |
by kurumi Wed, 05/24/2017 - 15:49 |
Reading a Simple Parameter using OBIS by Shehryar » Thu, 03/16/2017 - 15:20 |
3 |
by kurumi Tue, 05/16/2017 - 09:01 |
Read Landis+Gyr Meter by keenangeorge » Sun, 04/16/2017 - 13:46 |
4 |
by keenangeorge Tue, 04/18/2017 - 13:24 |
Having problem in connecting multiple GPRS(TCP/IP) meters. by Nitin Sethi » Fri, 03/17/2017 - 06:22 |
4 |
by kurumi Thu, 03/23/2017 - 08:35 |
ArgumentOutOfRangeException Exception: by Shehryar » Tue, 03/21/2017 - 14:59 |
3 |
by kurumi Thu, 03/23/2017 - 08:31 |
HPL smart meter to communicate through DLMS by manojit » Mon, 01/30/2017 - 13:59 |
14 |
by kurumi Wed, 02/22/2017 - 12:27 |
Profile Generic - Billing and Load Survey data reading This topic has been moved to "Gurux.DLMS" (View topic) |
Unable to connect to ISKRA MT 880 by Bakre » Wed, 11/02/2016 - 13:29 |
2 |
by Bakre Thu, 11/03/2016 - 13:05 |
UDP by max » Fri, 06/13/2014 - 13:06 |
4 |
by kurumi Mon, 06/30/2014 - 17:26 |
IPV6 by max » Mon, 06/16/2014 - 11:55 |
1 |
by kurumi Mon, 06/30/2014 - 16:37 |
GXNet csharp Sample project not found in the new verion svn by minhvc » Wed, 10/10/2012 - 03:55 |
2 |
by minhvc Mon, 10/29/2012 - 14:32 |
Delphi / Reading meter programmatically by leray » Wed, 07/11/2012 - 14:35 |
9 |
by kurumi Thu, 10/04/2012 - 12:18 |
problem to setup client/server tcp/ip connections by fbertoli » Fri, 03/18/2011 - 11:27 |
3 |
by kurumi Tue, 05/03/2011 - 09:48 |
how to implement parallel data collection processes by fbertoli » Mon, 03/21/2011 - 12:16 |
0 |
by fbertoli Mon, 03/21/2011 - 14:53 |
hex send data format for GXNET c# sample by fbertoli » Fri, 03/18/2011 - 10:50 |
1 |
by Administrator Mon, 03/21/2011 - 14:41 |
