Has anyone used this meter?
I have tried multiple presets and configurations with DLMSDirector - no response.
However I'm not even sure if DLMSDirector can support this meter. As far as I can translate and understand it is IEC 62053-21? Which might be a monophase version of 62056-21?
I've also tried sniffing out the communication between it's program "S0-Recorder" with no success. Possibly because it involves changing baudrates.
This meter is using IEC62053-21. IEC62053-21 is a different protocol than DLMS and for that reason you can't read it with GXDLMSDirector. http://www.gurux.fi/DLMSCOSEMFAQ
IEC62053-21 is ASCII based protocol, but I don't know is this meter just sending values or can you ask values from it. If it's just sending values, it's easy to handle. You can try if you select "Tools" and "Serial Monitor" in GXDLMSDirector. Then set correct serial port settings and check if you can see any output in the window.
A different protocol? Any idea where to find an implementation of it? Or a description of how it works so I can implement it. Can't find anything like that so far.
It definetely isn't just sending data - opening a monitor has never returned anything in the past regardless of settings. Its program does identification using the serial number, but that is where the need for a protocol implementation starts. That and taking readings from a Raspberry Pi.
The meter doesn't really return anything, probably why GXDMSDirector isn't working.
Tried again with the "/?!\r\n" sign on message, but the meter just echoes ("2F-3F-21-0D-0A" which is "/?!\r\n"). Including the serial number between "?" and "!" has no effect. Same result with a random string as a message.
Tried with 300/600/1200/9600/19200/115200, 7/8 data bits, even/odd/none, 1 stop bit - same result.
Could be the connection settings, but there isn't any documentation with the meter beyond installation instructions and the basics of how to use their S0-Recorder in German. Their program works, yes.
Any ideas?
If you have a working application you should use a serial port sniffer to get the data that the app is sending. When you have that information, I can help you to get started.
Okay, thanks, I'd appreciate really the decoding then.
However I've tried several options for sniffing without success.
Any recommendations for a sniffer software?
Hi again,
I coudn't get the Advanced Serial Port Monitor trial to work on the target machine.
So I tried others and settled on HHD Device Monitoring Studio. The only read/write data I captured in any program was a few "test_LoopbackRead".
The rest is raw capture data. A little of it I recondnize as DLMS message, but I'm not sure.
Any hints to settings or if it isn't actually DLMS?
IEC62053-21 is open protocol and meters are using it differently. That is the reason why Gurux is not supporting it.
You can try to send /?!\r\n. Meter should be reply back if your baud rate is correct.
Try with 9600 DataBits: 7, Parity: Even and StopBits: One.
You can try this with GXDMSDirector if you change the Interface From DLMS to DLMSWithModeE.
Then select "Advanced and try with different baud rates."
Miko
Any ideas?
We have a license for Advanced Serial Port Monitor. You can try that. It works quite well.
Hi again,
Hi again,
---------00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
000000 8A 01 00 00 00 5C 00 3F 00 3F 00 5C 00 46 00 54 .....\.?.?.\.F.T
000010 00 44 00 49 00 42 00 55 00 53 00 23 00 56 00 49 .D.I.B.U.S.#.V.I
000020 00 44 00 5F 00 30 00 34 00 30 00 33 00 2B 00 50 .D._.0.4.0.3.+.P
000030 00 49 00 44 00 5F 00 36 00 30 00 30 00 31 00 2B .I.D._.6.0.0.1.+
000040 00 46 00 54 00 46 00 43 00 41 00 47 00 56 00 56 .F.T.F.C.A.G.V.V
000050 00 41 00 23 00 30 00 30 00 30 00 30 00 23 00 7B .A.#.0.0.0.0.#.{
000060 00 30 00 31 00 30 00 30 00 66 00 64 00 64 00 37 .0.1.0.0.f.d.d.7
000070 00 2D 00 62 00 65 00 35 00 61 00 2D 00 34 00 38 .-.b.e.5.a.-.4.8
000080 00 30 00 38 00 2D 00 39 00 31 00 66 00 35 00 2D .0.8.-.9.1.f.5.-
000090 00 30 00 35 00 30 00 30 00 32 00 62 00 63 00 36 .0.5.0.0.2.b.c.6
0000A0 00 30 00 66 00 37 00 32 00 7D 00 10 3A 00 00 10 .0.f.7.2.}..:...
0000B0 3A 00 00 8A 08 00 1B 00 00 08 00 00 00 08 00 00 :...............
0000C0 8A 08 00 1B 00 8A 44 00 1B 00 C5 00 00 00 8A 44 ......D........D
0000D0 00 1B 00 8A 4C 00 1B 00 0F 00 00 00 FF 4C 00 1B ....L........L..
0000E0 00 8A 6C 00 1B 00 8A 6C 00 1B 00 00 00 00 00 00 ..l....l........
0000F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8A ................
000100 50 00 1B 00 00 50 00 1B 00 80 25 00 00 8A 54 00 P....P....%...T.
000110 1B 00 00 54 00 1B 00 00 00 08 8A 58 00 1B 00 00 ...T.......X....
000120 58 00 1B 00 00 00 00 00 00 00 8A 60 00 1B 00 00 X..........`....
000130 60 00 1B 00 01 00 00 00 00 00 00 80 00 08 00 00 `...............
000140 00 02 00 00 8A 50 00 1B 00 00 50 00 1B 00 80 25 .....P....P....%
000150 00 00 8A 54 00 1B 00 00 54 00 1B 00 00 00 08 8A ...T....T.......
000160 58 00 1B 00 00 58 00 1B 00 00 00 00 00 00 00 8A X....X..........
000170 60 00 1B 00 00 60 00 1B 00 01 00 00 00 00 00 00 `....`..........
000180 80 00 08 00 00 00 02 00 00 8A 04 00 1B 00 80 25 ...............%
000190 00 00 8A 04 00 1B 00 8A 30 00 1B 00 8A 30 00 1B ........0....0..
0001A0 00 8A 24 00 1B 00 8A 24 00 1B 00 8A 0C 00 1B 00 ..$....$........
0001B0 00 00 08 00 0C 00 1B 00 8A 5C 00 1B 00 00 00 00 .........\......
0001C0 00 00 01 00 5C 00 1B 00 8A 64 00 1B 00 01 00 00 ....\....d......
0001D0 00 40 00 00 80 00 02 00 00 00 02 00 00 00 64 00 .@............d.
0001E0 1B 00 8A 20 00 1B 00 00 20 00 1B 00 2C 01 00 00 ... .... ...,...
0001F0 32 00 00 00 64 00 00 00 05 00 00 00 E8 03 00 00 2...d...........
000200 8A 1C 00 1B 00 F4 01 00 00 50 00 00 00 C8 00 00 .........P......
000210 00 28 00 00 00 3C 00 00 00 00 1C 00 1B 00 8A 40 .(...<.........@
000220 00 1B 00 00 40 00 1B 00 C5 00 00 00 8A 20 00 1B ....@........ ..
000230 00 00 20 00 1B 00 F4 01 00 00 50 00 00 00 C8 00 .. .......P.....
000240 00 00 28 00 00 00 3C 00 00 00 8A 1C 00 1B 00 F4 ..(...<.........
000250 01 00 00 50 00 00 00 C8 00 00 00 28 00 00 00 3C ...P.......(...<
000260 00 00 00 00 1C 00 1B 00 8A 24 00 1B 00 8A 24 00 .........$....$.
000270 1B 00 8A 30 00 1B 00 8A 30 00 1B 00 8A 4C 00 1B ...0....0....L..
000280 00 0F 00 00 00 8A 4C 00 1B 00 8A 03 00 00 00 FF ......L.........
000290 03 00 00 00 8A 6C 00 1B 00 8A 6C 00 1B 00 00 00 .....l....l.....
0002A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0002B0 00 00 8A 03 00 00 00 FF 03 00 00 00 8A 6C 00 1B .............l..
0002C0 00 00 6C 00 1B 00 00 00 00 00 00 00 00 00 00 00 ..l.............
0002D0 00 00 00 00 00 00 00 00 00 00 8A 03 00 00 00 FF ................
0002E0 03 00 00 00 8A 6C 00 1B 00 00 6C 00 1B 00 00 00 .....l....l.....
0002F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
000300 00 00 8A 03 00 00 00 00 03 00 00 00 8A 6C 00 1B .............l..
000310 00 00 6C 00 1B 00 00 00 00 00 00 00 00 00 00 00 ..l.............
000320 00 00 00 00 00 00 00 00 00 00 8A 03 00 00 00 00 ................
000330 03 00 00 00 8A 6C 00 1B 00 00 6C 00 1B 00 00 00 .....l....l.....
000340 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
000350 00 00 8A 03 00 00 00 FF 03 00 00 00 8A 6C 00 1B .............l..
000360 00 00 6C 00 1B 00 00 00 00 00 00 00 00 00 00 00 ..l.............
000370 00 00 00 00 00 00 00 00 00 00 8A 03 00 00 00 FF ................
000380 03 00 00 00 8A 6C 00 1B 00 00 6C 00 1B 00 00 00 .....l....l.....
000390 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0003A0 00 00 8A 50 00 1B 00 00 50 00 1B 00 80 25 00 00 ...P....P....%..
0003B0 8A 54 00 1B 00 00 54 00 1B 00 00 00 08 8A 58 00 .T....T.......X.
0003C0 1B 00 00 58 00 1B 00 00 00 00 00 00 01 8A 60 00 ...X..........`.
0003D0 1B 00 00 60 00 1B 00 01 00 00 00 40 00 00 80 00 ...`.......@....
0003E0 02 00 00 00 02 00 00 8A 4C 00 1B 00 0F 00 00 00 ........L.......
0003F0 8A 4C 00 1B 00 8A 6C 00 1B 00 8A 6C 00 1B 00 00 .L....l....l....
000400 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
000410 00 00 00 8A 50 00 1B 00 00 50 00 1B 00 80 25 00 ....P....P....%.
000420 00 8A 54 00 1B 00 00 54 00 1B 00 00 00 08 8A 58 ..T....T.......X
000430 00 1B 00 00 58 00 1B 00 00 00 00 00 00 01 8A 60 ....X..........`
000440 00 1B 00 00 60 00 1B 00 01 00 00 00 40 00 00 80 ....`.......@...
000450 00 02 00 00 00 02 00 00 8A 50 00 1B 00 00 50 00 .........P....P.
000460 1B 00 80 25 00 00 8A 54 00 1B 00 00 54 00 1B 00 ...%...T....T...
000470 00 00 08 8A 58 00 1B 00 00 58 00 1B 00 00 00 00 ....X....X......
000480 00 00 01 8A 60 00 1B 00 00 60 00 1B 00 01 00 00 ....`....`......
000490 00 40 00 00 80 00 02 00 00 00 02 00 00 8A 04 00 .@..............
0004A0 1B 00 80 25 00 00 8A 04 00 1B 00 8A 30 00 1B 00 ...%........0...
0004B0 8A 30 00 1B 00 8A 24 00 1B 00 8A 24 00 1B 00 8A .0....$....$....
0004C0 0C 00 1B 00 00 00 08 00 0C 00 1B 00 8A 5C 00 1B .............\..
0004D0 00 00 00 00 00 00 01 00 5C 00 1B 00 8A 64 00 1B ........\....d..
0004E0 00 01 00 00 00 40 00 00 80 00 02 00 00 00 02 00 .....@..........
0004F0 00 00 64 00 1B 00 8A 20 00 1B 00 00 20 00 1B 00 ..d.... .... ...
000500 F4 01 00 00 50 00 00 00 C8 00 00 00 28 00 00 00 ....P.......(...
000510 3C 00 00 00 8A 1C 00 1B 00 F4 01 00 00 50 00 00 <............P..
000520 00 C8 00 00 00 28 00 00 00 3C 00 00 00 00 1C 00 .....(...<......
000530 1B 00 8A 40 00 1B 00 00 40 00 1B 00 C5 00 00 00 ...@....@.......
000540 8A 50 00 1B 00 00 50 00 1B 00 80 25 00 00 8A 54 .P....P....%...T
000550 00 1B 00 00 54 00 1B 00 00 00 08 8A 58 00 1B 00 ....T.......X...
000560 00 58 00 1B 00 00 00 00 00 00 01 8A 60 00 1B 00 .X..........`...
000570 00 60 00 1B 00 01 00 00 00 40 00 00 80 00 02 00 .`.......@......
000580 00 00 02 00 00 8A 68 00 1B 00 00 68 00 1B 00 70 ......h....h...p
000590 00 00 00 8A 34 00 1B 00 8A 34 00 1B 00 8A 68 00 ....4....4....h.
0005A0 1B 00 00 68 00 1B 00 20 00 00 00 8A 30 00 1B 00 ...h... ....0...
0005B0 8A 30 00 1B 00 8A 68 00 1B 00 00 68 00 1B 00 30 .0....h....h...0
0005C0 00 00 00 8A 50 00 1B 00 00 50 00 1B 00 80 25 00 ....P....P....%.
0005D0 00 8A 54 00 1B 00 00 54 00 1B 00 00 00 08 8A 58 ..T....T.......X
0005E0 00 1B 00 00 58 00 1B 00 00 00 00 00 00 01 8A 60 ....X..........`
0005F0 00 1B 00 00 60 00 1B 00 01 00 00 00 40 00 00 80 ....`.......@...
000600 00 02 00 00 00 02 00 00 8A 68 00 1B 00 00 68 00 .........h....h.
000610 1B 00 30 00 00 00 8A 28 00 1B 00 8A 28 00 1B 00 ..0....(....(...
000620 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 24 .h....h........$
000630 00 1B 00 8A 24 00 1B 00 8A 68 00 1B 00 00 68 00 ....$....h....h.
000640 1B 00 30 00 00 00 8A 50 00 1B 00 00 50 00 1B 00 ..0....P....P...
000650 80 25 00 00 8A 54 00 1B 00 00 54 00 1B 00 00 00 .%...T....T.....
000660 08 8A 58 00 1B 00 00 58 00 1B 00 00 00 00 00 00 ..X....X........
000670 01 8A 60 00 1B 00 00 60 00 1B 00 01 00 00 00 40 ..`....`.......@
000680 00 00 80 00 02 00 00 00 02 00 00 8A 50 00 1B 00 ............P...
000690 00 50 00 1B 00 80 25 00 00 8A 54 00 1B 00 00 54 .P....%...T....T
0006A0 00 1B 00 00 00 08 8A 58 00 1B 00 00 58 00 1B 00 .......X....X...
0006B0 00 00 00 00 00 01 8A 60 00 1B 00 00 60 00 1B 00 .......`....`...
0006C0 01 00 00 00 40 00 00 80 00 02 00 00 00 02 00 00 ....@...........
0006D0 8A 04 00 1B 00 00 C2 01 00 8A 04 00 1B 00 8A 30 ...............0
0006E0 00 1B 00 8A 30 00 1B 00 8A 24 00 1B 00 8A 24 00 ....0....$....$.
0006F0 1B 00 8A 0C 00 1B 00 00 00 08 00 0C 00 1B 00 8A ................
000700 5C 00 1B 00 00 00 00 00 00 01 00 5C 00 1B 00 8A \..........\....
000710 64 00 1B 00 01 00 00 00 40 00 00 80 00 02 00 00 d.......@.......
000720 00 02 00 00 8A 64 00 1B 00 8A 1C 00 1B 00 00 00 .....d..........
000730 00 00 00 00 00 00 E8 03 00 00 00 00 00 00 00 00 ................
000740 00 00 00 1C 00 1B 00 8A 44 00 1B 00 04 00 00 00 ........D.......
000750 8A 44 00 1B 00 8A 04 00 00 00 74 65 73 74 5F 4C .D........test_L
000760 6F 6F 70 62 61 63 6B 52 65 61 64 00 8A 04 00 00 oopbackRead.....
000770 00 74 65 73 74 5F 4C 6F 6F 70 62 61 63 6B 52 65 .test_LoopbackRe
000780 61 64 00 8A 03 00 00 00 FF 03 00 00 00 74 65 73 ad...........tes
000790 74 5F 4C 6F 6F 70 62 61 63 6B 52 65 61 64 00 8A t_LoopbackRead..
0007A0 50 00 1B 00 06 50 00 1B 00 00 C2 01 00 8A 54 00 P....P........T.
0007B0 1B 00 00 54 00 1B 00 00 00 08 8A 58 00 1B 00 00 ...T.......X....
0007C0 58 00 1B 00 00 00 00 00 00 01 8A 60 00 1B 00 00 X..........`....
0007D0 60 00 1B 00 01 00 00 00 40 00 00 80 00 02 00 00 `.......@.......
0007E0 00 02 00 00 8A 50 00 1B 00 00 50 00 1B 00 00 C2 .....P....P.....
0007F0 01 00 8A 54 00 1B 00 00 54 00 1B 00 00 00 08 8A ...T....T.......
000800 58 00 1B 00 00 58 00 1B 00 00 00 00 00 00 01 8A X....X..........
000810 60 00 1B 00 00 60 00 1B 00 01 00 00 00 40 00 00 `....`.......@..
000820 80 00 02 00 00 00 02 00 00 8A 04 00 1B 00 80 25 ...............%
000830 00 00 8A 04 00 1B 00 8A 30 00 1B 00 8A 30 00 1B ........0....0..
000840 00 8A 24 00 1B 00 8A 24 00 1B 00 8A 0C 00 1B 00 ..$....$........
000850 00 00 08 00 0C 00 1B 00 8A 5C 00 1B 00 00 00 00 .........\......
000860 00 00 01 00 5C 00 1B 00 8A 64 00 1B 00 01 00 00 ....\....d......
000870 00 40 00 00 80 00 02 00 00 00 02 00 00 8A 64 00 .@............d.
000880 1B 00 8A 44 00 1B 00 01 00 00 00 8A 44 00 1B 00 ...D........D...
000890 8A 04 00 00 00 74 65 73 74 5F 4C 6F 6F 70 62 61 .....test_Loopba
0008A0 63 6B 52 65 61 64 00 00 04 00 00 00 74 65 73 74 ckRead......test
0008B0 5F 4C 6F 6F 70 62 61 63 6B 52 65 61 64 00 8A 48 _LoopbackRead..H
0008C0 00 1B 00 8A 48 00 1B 00 01 00 00 00 00 03 00 00 ....H...........
0008D0 00 FF 03 00 00 00 74 65 73 74 5F 4C 6F 6F 70 62 ......test_Loopb
0008E0 61 63 6B 52 65 61 64 00 8A 50 00 1B 00 8A 50 00 ackRead..P....P.
0008F0 1B 00 80 25 00 00 8A 54 00 1B 00 00 54 00 1B 00 ...%...T....T...
000900 00 00 08 8A 58 00 1B 00 00 58 00 1B 00 00 00 00 ....X....X......
000910 00 00 01 8A 60 00 1B 00 00 60 00 1B 00 01 00 00 ....`....`......
000920 00 40 00 00 80 00 02 00 00 00 02 00 00 8A 04 00 .@..............
000930 1B 00 80 25 00 00 8A 04 00 1B 00 00 30 00 1B 00 ...%........0...
000940 8A 30 00 1B 00 8A 24 00 1B 00 8A 24 00 1B 00 8A .0....$....$....
000950 0C 00 1B 00 00 00 08 00 0C 00 1B 00 8A 5C 00 1B .............\..
000960 00 00 00 00 00 00 01 00 5C 00 1B 00 8A 64 00 1B ........\....d..
000970 00 01 00 00 00 40 00 00 80 00 02 00 00 00 02 00 .....@..........
000980 00 8A 64 00 1B 00 8A 04 00 00 00 74 65 73 74 5F ..d........test_
000990 4C 6F 6F 70 62 61 63 6B 52 65 61 64 00 8A 04 00 LoopbackRead....
0009A0 00 00 74 65 73 74 5F 4C 6F 6F 70 62 61 63 6B 52 ..test_LoopbackR
0009B0 65 61 64 00 8A 03 00 00 00 00 03 00 00 00 74 65 ead...........te
0009C0 73 74 00 03 00 00 00 00 03 00 00 00 5F 4C 6F 6F st.........._Loo
0009D0 00 03 00 00 00 00 03 00 00 00 70 62 61 63 00 03 ..........pbac..
0009E0 00 00 00 00 03 00 00 00 6B 52 65 61 00 03 00 00 ........kRea....
0009F0 00 FF 03 00 00 00 64 00 8A 4C 00 1B 00 0F 00 00 ......d..L......
000A00 00 32 4C 00 1B 00 8A 44 00 1B 00 00 00 00 00 8A .2L....D........
000A10 44 00 1B 00 8A 28 00 1B 00 8A 28 00 1B 00 8A 34 D....(....(....4
000A20 00 1B 00 8A 34 00 1B 00 8A 4C 00 1B 00 0F 00 00 ....4....L......
000A30 00 8A 4C 00 1B 00 8A 02 00 00 00 06 02 00 00 00 ..L.............
000A40 10 3A 00 00 10 3A 00 00 8A 08 00 1B 00 00 08 00 .:...:..........
000A50 00 00 08 00 00 8A 08 00 1B 00 8A 44 00 1B 00 C5 ...........D....
000A60 00 00 00 8A 44 00 1B 00 8A 4C 00 1B 00 0F 00 00 ....D....L......
000A70 00 FF 4C 00 1B 00 8A 6C 00 1B 00 8A 6C 00 1B 00 ..L....l....l...
000A80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
000A90 00 00 00 00 8A 50 00 1B 00 00 50 00 1B 00 80 25 .....P....P....%
000AA0 00 00 8A 54 00 1B 00 00 54 00 1B 00 00 00 08 8A ...T....T.......
000AB0 58 00 1B 00 00 58 00 1B 00 00 00 00 00 00 01 8A X....X..........
000AC0 60 00 1B 00 00 60 00 1B 00 01 00 00 00 40 00 00 `....`.......@..
000AD0 80 00 08 00 00 00 02 00 00 8A 50 00 1B 00 06 50 ..........P....P
000AE0 00 1B 00 80 25 00 00 8A 54 00 1B 00 00 54 00 1B ....%...T....T..
000AF0 00 00 00 08 8A 58 00 1B 00 00 58 00 1B 00 00 00 .....X....X.....
000B00 00 00 00 01 8A 60 00 1B 00 00 60 00 1B 00 01 00 .....`....`.....
000B10 00 00 40 00 00 80 00 08 00 00 00 02 00 00 8A 04 ..@.............
000B20 00 1B 00 80 25 00 00 8A 04 00 1B 00 8A 34 00 1B ....%........4..
000B30 00 8A 34 00 1B 00 8A 24 00 1B 00 8A 24 00 1B 00 ..4....$....$...
000B40 8A 0C 00 1B 00 00 00 08 00 0C 00 1B 00 8A 5C 00 ..............\.
000B50 1B 00 00 00 00 00 00 00 00 5C 00 1B 00 8A 64 00 .........\....d.
000B60 1B 00 01 00 00 00 00 00 00 80 00 04 00 00 00 04 ................
000B70 00 00 8A 64 00 1B 00 8A 20 00 1B 00 00 20 00 1B ...d.... .... ..
000B80 00 00 00 00 00 00 00 00 00 E8 03 00 00 00 00 00 ................
000B90 00 00 00 00 00 8A 1C 00 1B 00 2C 01 00 00 32 00 ..........,...2.
000BA0 00 00 64 00 00 00 05 00 00 00 E8 03 00 00 00 1C ..d.............
000BB0 00 1B 00 8A 40 00 1B 00 00 40 00 1B 00 C5 00 00 ....@....@......
000BC0 00 8A 20 00 1B 00 00 20 00 1B 00 2C 01 00 00 32 .. .... ...,...2
000BD0 00 00 00 64 00 00 00 05 00 00 00 E8 03 00 00 8A ...d............
000BE0 1C 00 1B 00 2C 01 00 00 32 00 00 00 64 00 00 00 ....,...2...d...
000BF0 05 00 00 00 E8 03 00 00 00 1C 00 1B 00 8A 50 00 ..............P.
000C00 1B 00 00 50 00 1B 00 80 25 00 00 8A 54 00 1B 00 ...P....%...T...
000C10 00 54 00 1B 00 00 00 08 8A 58 00 1B 00 00 58 00 .T.......X....X.
000C20 1B 00 00 00 00 00 00 00 8A 60 00 1B 00 00 60 00 .........`....`.
000C30 1B 00 01 00 00 00 00 00 00 80 00 04 00 00 00 04 ................
000C40 00 00 8A 68 00 1B 00 00 68 00 1B 00 20 00 00 00 ...h....h... ...
000C50 8A 24 00 1B 00 8A 24 00 1B 00 8A 68 00 1B 00 00 .$....$....h....
000C60 68 00 1B 00 20 00 00 00 8A 50 00 1B 00 00 50 00 h... ....P....P.
000C70 1B 00 80 25 00 00 8A 54 00 1B 00 00 54 00 1B 00 ...%...T....T...
000C80 00 00 08 8A 58 00 1B 00 00 58 00 1B 00 00 00 00 ....X....X......
000C90 00 00 00 8A 60 00 1B 00 00 60 00 1B 00 01 00 00 ....`....`......
000CA0 00 00 00 00 80 00 04 00 00 00 04 00 00 8A 68 00 ..............h.
000CB0 1B 00 00 68 00 1B 00 20 00 00 00 8A 24 00 1B 00 ...h... ....$...
000CC0 8A 24 00 1B 00 8A 68 00 1B 00 00 68 00 1B 00 20 .$....h....h...
000CD0 00 00 00 8A 28 00 1B 00 8A 28 00 1B 00 8A 30 00 ....(....(....0.
000CE0 1B 00 8A 30 00 1B 00 8A 68 00 1B 00 00 68 00 1B ...0....h....h..
000CF0 00 10 00 00 00 8A 6C 00 1B 00 00 6C 00 1B 00 00 ......l....l....
000D00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
000D10 00 00 00 8A 44 00 1B 00 00 01 00 00 8A 44 00 1B ....D........D..
000D20 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A ..H....H........
000D30 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
000D40 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
000D50 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
000D60 00 1B 00 10 00 00 00 8A 48 00 1B 00 06 48 00 1B ........H....H..
000D70 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
000D80 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
000D90 00 8A 48 00 1B 00 B2 48 00 1B 00 00 01 00 00 8A ..H....H........
000DA0 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
000DB0 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
000DC0 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 .h........H....H
000DD0 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
000DE0 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
000DF0 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 ....H....H......
000E00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
000E10 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
000E20 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
000E30 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 06 48 .h........H....H
000E40 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
000E50 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
000E60 00 00 00 8A 48 00 1B 00 8A 48 00 1B 00 00 01 00 ....H....H......
000E70 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
000E80 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
000E90 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
000EA0 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
000EB0 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
000EC0 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 ......H....H....
000ED0 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
000EE0 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
000EF0 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
000F00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
000F10 06 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
000F20 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
000F30 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 ......H....H....
000F40 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
000F50 00 00 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
000F60 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
000F70 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
000F80 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 .h........h....h
000F90 00 1B 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B ........H....H..
000FA0 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 ......h....h...P
000FB0 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 ....h....h...P..
000FC0 00 00 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
000FD0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
000FE0 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
000FF0 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 .h........h....h
001000 00 1B 00 10 00 00 00 8A 48 00 1B 00 B2 48 00 1B ........H....H..
001010 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 ......h....h...P
001020 00 00 00 00 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
001030 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001040 48 00 1B 00 06 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
001050 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 ...h........h...
001060 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 .h........H....H
001070 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
001080 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 .P....h....h...P
001090 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
0010A0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
0010B0 48 00 1B 00 06 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
0010C0 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 ...h........h...
0010D0 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 .h........H....H
0010E0 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
0010F0 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 .P....h....h...P
001100 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001110 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A ..H....H........
001120 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 h....h........h.
001130 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
001140 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
001150 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B ...P....h....h..
001160 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 .P....h....h...P
001170 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001180 00 8A 48 00 1B 00 18 48 00 1B 00 00 01 00 00 8A ..H....H........
001190 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 h....h........h.
0011A0 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
0011B0 06 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
0011C0 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B ...P....h....h..
0011D0 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 .P....h....h....
0011E0 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 01 00 ....H....H......
0011F0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001200 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
001210 1B 00 B2 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
001220 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 .h...P....h....h
001230 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
001240 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 .P....h....h....
001250 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 ....H....H......
001260 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001270 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
001280 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
001290 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
0012A0 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
0012B0 00 10 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 ......H....H....
0012C0 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
0012D0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
0012E0 48 00 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
0012F0 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
001300 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
001310 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
001320 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B 00 00 ......H....H....
001330 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001340 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001350 48 00 1B 00 B2 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
001360 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
001370 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
001380 00 1B 00 10 00 00 00 8A 48 00 1B 00 18 48 00 1B ........H....H..
001390 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
0013A0 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
0013B0 00 8A 48 00 1B 00 06 48 00 1B 00 00 01 00 00 8A ..H....H........
0013C0 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
0013D0 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
0013E0 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
0013F0 00 1B 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B ........H....H..
001400 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
001410 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001420 00 8A 48 00 1B 00 8A 48 00 1B 00 00 01 00 00 8A ..H....H........
001430 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
001440 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
001450 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 06 48 .h........H....H
001460 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
001470 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
001480 00 00 00 8A 48 00 1B 00 8A 48 00 1B 00 00 01 00 ....H....H......
001490 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
0014A0 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
0014B0 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
0014C0 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 00 48 .h........H....H
0014D0 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
0014E0 00 10 00 00 00 00 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
0014F0 00 00 00 00 48 00 1B 00 00 48 00 1B 00 00 01 00 ....H....H......
001500 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
001510 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
001520 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
001530 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
001540 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
001550 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 ......H....H....
001560 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
001570 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A ..h....h...P....
001580 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
001590 1B 00 00 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
0015A0 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 .h........h....h
0015B0 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B ........H....H..
0015C0 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 ......h....h...P
0015D0 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 ....h....h...P..
0015E0 00 00 68 00 1B 00 00 68 00 1B 00 10 00 00 00 00 ..h....h........
0015F0 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
001600 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 ...h........h...
001610 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 .h........H....H
001620 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
001630 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 .P....h....h...P
001640 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
001650 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001660 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
001670 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 ...h........h...
001680 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 00 48 .h........H....H
001690 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
0016A0 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 .P....h....h...P
0016B0 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
0016C0 00 8A 48 00 1B 00 18 48 00 1B 00 00 01 00 00 8A ..H....H........
0016D0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 h....h........h.
0016E0 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
0016F0 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
001700 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B ...P....h....h..
001710 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 .P....h....h...P
001720 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001730 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A ..H....H........
001740 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 h....h........h.
001750 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
001760 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
001770 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B ...P....h....h..
001780 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 .P....h....h....
001790 00 00 00 8A 48 00 1B 00 8A 48 00 1B 00 00 01 00 ....H....H......
0017A0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
0017B0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
0017C0 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
0017D0 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 .h...P....h....h
0017E0 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
0017F0 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 .P....h....h....
001800 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 01 00 ....H....H......
001810 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001820 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
001830 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
001840 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 .h...P....h....h
001850 00 1B 00 50 00 00 00 06 68 00 1B 00 06 68 00 1B ...P....h....h..
001860 00 10 00 00 00 06 48 00 1B 00 FF 48 00 1B 00 00 ......H....H....
001870 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001880 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001890 48 00 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
0018A0 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
0018B0 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
0018C0 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
0018D0 00 10 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 ......H....H....
0018E0 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
0018F0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001900 48 00 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
001910 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
001920 00 68 00 1B 00 50 00 00 00 00 68 00 1B 00 00 68 .h...P....h....h
001930 00 1B 00 10 00 00 00 00 48 00 1B 00 00 48 00 1B ........H....H..
001940 00 00 01 00 00 00 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
001950 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001960 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A ..H....H........
001970 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
001980 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
001990 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
0019A0 00 1B 00 10 00 00 00 8A 48 00 1B 00 06 48 00 1B ........H....H..
0019B0 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
0019C0 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
0019D0 00 8A 48 00 1B 00 8A 48 00 1B 00 00 01 00 00 8A ..H....H........
0019E0 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
0019F0 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
001A00 00 68 00 1B 00 10 00 00 00 00 48 00 1B 00 00 48 .h........H....H
001A10 00 1B 00 00 01 00 00 00 68 00 1B 00 8A 68 00 1B ........h....h..
001A20 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
001A30 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 01 00 ....H....H......
001A40 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
001A50 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
001A60 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
001A70 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 06 48 .h........H....H
001A80 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
001A90 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
001AA0 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 ....H....H......
001AB0 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
001AC0 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 00 68 00 h....h...P....h.
001AD0 1B 00 00 68 00 1B 00 10 00 00 00 00 48 00 1B 00 ...h........H...
001AE0 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
001AF0 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
001B00 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B 00 00 ......H....H....
001B10 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
001B20 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A ..h....h...P....
001B30 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
001B40 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
001B50 00 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
001B60 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
001B70 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B 00 00 ......H....H....
001B80 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
001B90 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A ..h....h...P....
001BA0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
001BB0 1B 00 00 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
001BC0 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 .h........h....h
001BD0 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B ........H....H..
001BE0 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 ......h....h...P
001BF0 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 ....h....h...P..
001C00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
001C10 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
001C20 1B 00 06 48 00 1B 00 00 01 00 00 00 68 00 1B 00 ...H........h...
001C30 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 .h........h....h
001C40 00 1B 00 10 00 00 00 00 48 00 1B 00 00 48 00 1B ........H....H..
001C50 00 00 01 00 00 00 68 00 1B 00 00 68 00 1B 00 50 ......h....h...P
001C60 00 00 00 00 68 00 1B 00 8A 68 00 1B 00 50 00 00 ....h....h...P..
001C70 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001C80 48 00 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
001C90 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 ...h........h...
001CA0 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 00 48 .h........H....H
001CB0 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
001CC0 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 .P....h....h...P
001CD0 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
001CE0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001CF0 48 00 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
001D00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 ...h........h...
001D10 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 .h........H....H
001D20 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
001D30 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 .P....h....h...P
001D40 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001D50 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A ..H....H........
001D60 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 h....h........h.
001D70 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
001D80 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
001D90 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B ...P....h....h..
001DA0 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 .P....h....h...P
001DB0 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001DC0 00 8A 48 00 1B 00 06 48 00 1B 00 00 01 00 00 8A ..H....H........
001DD0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 h....h........h.
001DE0 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
001DF0 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
001E00 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
001E10 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 .P....h....h....
001E20 00 00 00 8A 48 00 1B 00 8A 48 00 1B 00 00 01 00 ....H....H......
001E30 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001E40 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
001E50 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
001E60 06 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
001E70 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
001E80 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 .P....h....h....
001E90 00 00 00 8A 48 00 1B 00 8A 48 00 1B 00 00 01 00 ....H....H......
001EA0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001EB0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
001EC0 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
001ED0 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
001EE0 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
001EF0 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 ......H....H....
001F00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001F10 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001F20 48 00 1B 00 B2 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
001F30 1B 00 06 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
001F40 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
001F50 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
001F60 00 10 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 ......H....H....
001F70 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001F80 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
001F90 48 00 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
001FA0 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
001FB0 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
001FC0 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B ........H....H..
001FD0 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
001FE0 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
001FF0 00 8A 48 00 1B 00 8A 48 00 1B 00 00 01 00 00 8A ..H....H........
002000 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
002010 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
002020 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
002030 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B ........H....H..
002040 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
002050 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
002060 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A ..H....H........
002070 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
002080 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
002090 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 00 48 .h........H....H
0020A0 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
0020B0 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
0020C0 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 ....H....H......
0020D0 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
0020E0 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
0020F0 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
002100 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 06 48 .h........H....H
002110 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002120 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
002130 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 ....H....H......
002140 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
002150 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
002160 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
002170 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
002180 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002190 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 ......H....H....
0021A0 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
0021B0 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A ..h....h...P....
0021C0 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
0021D0 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
0021E0 00 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
0021F0 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002200 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 ......H....H....
002210 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
002220 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A ..h....h...P....
002230 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
002240 1B 00 06 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
002250 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 .h........h....h
002260 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B ........H....H..
002270 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 ......h....h...P
002280 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 ....h....h...P..
002290 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
0022A0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
0022B0 1B 00 06 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
0022C0 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 .h........h....h
0022D0 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B ........H....H..
0022E0 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 ......h....h...P
0022F0 00 00 00 00 68 00 1B 00 8A 68 00 1B 00 50 00 00 ....h....h...P..
002300 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
002310 48 00 1B 00 06 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
002320 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 ...h........h...
002330 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 00 48 .h........H....H
002340 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002350 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 .P....h....h...P
002360 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
002370 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 00 ..h....h........
002380 48 00 1B 00 06 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
002390 1B 00 8A 68 00 1B 00 10 00 00 00 00 68 00 1B 00 ...h........h...
0023A0 00 68 00 1B 00 10 00 00 00 00 48 00 1B 00 B2 48 .h........H....H
0023B0 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
0023C0 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 .P....h....h...P
0023D0 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
0023E0 00 8A 48 00 1B 00 06 48 00 1B 00 00 01 00 00 8A ..H....H........
0023F0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 h....h........h.
002400 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
002410 00 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
002420 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B ...P....h....h..
002430 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 .P....h....h...P
002440 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
002450 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A ..H....H........
002460 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 h....h........h.
002470 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
002480 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
002490 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B ...P....h....h..
0024A0 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 .P....h....h....
0024B0 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 01 00 ....H....H......
0024C0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
0024D0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
0024E0 1B 00 00 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
0024F0 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 .h...P....h....h
002500 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
002510 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 .P....h....h....
002520 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 01 00 ....H....H......
002530 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
002540 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
002550 1B 00 00 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
002560 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 .h...P....h....h
002570 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
002580 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 ......H....H....
002590 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
0025A0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
0025B0 48 00 1B 00 B2 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
0025C0 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
0025D0 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
0025E0 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
0025F0 00 10 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 ......H....H....
002600 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
002610 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
002620 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
002630 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
002640 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
002650 00 1B 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B ........H....H..
002660 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
002670 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
002680 00 8A 48 00 1B 00 B2 48 00 1B 00 00 01 00 00 8A ..H....H........
002690 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
0026A0 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
0026B0 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
0026C0 00 1B 00 10 00 00 00 8A 48 00 1B 00 06 48 00 1B ........H....H..
0026D0 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
0026E0 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
0026F0 00 8A 48 00 1B 00 8A 48 00 1B 00 00 01 00 00 8A ..H....H........
002700 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
002710 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
002720 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 06 48 .h........H....H
002730 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002740 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
002750 00 00 00 8A 48 00 1B 00 8A 48 00 1B 00 00 01 00 ....H....H......
002760 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A ..h....h...P....
002770 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
002780 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
002790 00 68 00 1B 00 10 00 00 00 00 48 00 1B 00 06 48 .h........H....H
0027A0 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
0027B0 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
0027C0 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 ....H....H......
0027D0 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
0027E0 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 48 68 00 h....h...P...Hh.
0027F0 1B 00 06 68 00 1B 00 10 00 00 00 48 48 00 1B 00 ...h.......HH...
002800 00 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
002810 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002820 00 10 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 ......H....H....
002830 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
002840 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
002850 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
002860 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
002870 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
002880 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002890 00 10 00 00 00 8A 48 00 1B 00 B2 48 00 1B 00 00 ......H....H....
0028A0 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
0028B0 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A ..h....h...P....
0028C0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
0028D0 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
0028E0 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 .h........h....h
0028F0 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B ........H....H..
002900 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 ......h....h...P
002910 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 ....h....h...P..
002920 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
002930 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
002940 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
002950 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 .h........h....h
002960 00 1B 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B ........H....H..
002970 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 ......h....h...P
002980 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 ....h....h...P..
002990 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
0029A0 48 00 1B 00 06 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
0029B0 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 ...h........h...
0029C0 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 .h........H....H
0029D0 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
0029E0 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 .P....h....h...P
0029F0 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
002A00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
002A10 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
002A20 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 ...h........h...
002A30 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 .h........H....H
002A40 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002A50 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 .P....h....h...P
002A60 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
002A70 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A ..H....H........
002A80 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 h....h........h.
002A90 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
002AA0 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
002AB0 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B ...P....h....h..
002AC0 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 .P....h....h...P
002AD0 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
002AE0 00 8A 48 00 1B 00 06 48 00 1B 00 00 01 00 00 8A ..H....H........
002AF0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 68 00 h....h........h.
002B00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
002B10 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
002B20 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 00 1B ...P....h....h..
002B30 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 .P....h....h....
002B40 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 01 00 ....H....H......
002B50 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
002B60 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
002B70 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
002B80 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 .h...P....h....h
002B90 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
002BA0 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 .P....h....h....
002BB0 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 01 00 ....H....H......
002BC0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
002BD0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
002BE0 1B 00 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
002BF0 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 8A 68 .h...P....h....h
002C00 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
002C10 00 10 00 00 00 8A 48 00 1B 00 06 48 00 1B 00 00 ......H....H....
002C20 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
002C30 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
002C40 48 00 1B 00 B2 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
002C50 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
002C60 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
002C70 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 00 1B ...P....h....h..
002C80 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B 00 00 ......H....H....
002C90 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
002CA0 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A ..h....h........
002CB0 48 00 1B 00 00 48 00 1B 00 00 01 00 00 8A 68 00 H....H........h.
002CC0 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
002CD0 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 00 68 .h...P....h....h
002CE0 00 1B 00 10 00 00 00 8A 48 00 1B 00 06 48 00 1B ........H....H..
002CF0 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
002D00 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 00 00 ....h....h......
002D10 00 8A 48 00 1B 00 B2 48 00 1B 00 00 01 00 00 8A ..H....H........
002D20 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
002D30 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 1B 00 ...h...P....h...
002D40 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 00 48 .h........H....H
002D50 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002D60 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B 00 10 ......h....h....
002D70 00 00 00 00 48 00 1B 00 B2 48 00 1B 00 00 01 00 ....H....H......
002D80 00 8A 68 00 1B 00 48 68 00 1B 00 50 00 00 00 8A ..h...Hh...P....
002D90 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
002DA0 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
002DB0 8A 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
002DC0 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002DD0 00 10 00 00 00 8A 48 00 1B 00 B2 48 00 1B 00 00 ......H....H....
002DE0 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
002DF0 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A ..h....h...P....
002E00 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A 68 00 h....h...P....h.
002E10 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 1B 00 ...h........H...
002E20 00 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 00 68 .H........h....h
002E30 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 00 1B ........h....h..
002E40 00 10 00 00 00 8A 48 00 1B 00 00 48 00 1B 00 00 ......H....H....
002E50 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 ....h....h...P..
002E60 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 00 8A ..h....h...P....
002E70 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 48 00 h....h........H.
002E80 1B 00 06 48 00 1B 00 00 01 00 00 8A 68 00 1B 00 ...H........h...
002E90 00 68 00 1B 00 10 00 00 00 8A 68 00 1B 00 00 68 .h........h....h
002EA0 00 1B 00 10 00 00 00 8A 48 00 1B 00 8A 48 00 1B ........H....H..
002EB0 00 00 01 00 00 8A 68 00 1B 00 00 68 00 1B 00 50 ......h....h...P
002EC0 00 00 00 8A 68 00 1B 00 8A 68 00 1B 00 50 00 00 ....h....h...P..
002ED0 00 8A 68 00 1B 00 00 68 00 1B 00 50 00 00 00 8A ..h....h...P....
002EE0 68 00 1B 00 00 68 00 1B 00 10 00 00 00 8A 4C 00 h....h........L.
002EF0 1B 00 0F 00 00 00 8A 4C 00 1B 00 8A 44 00 1B 00 .......L....D...
002F00 00 00 00 00 8A 44 00 1B 00 8A 28 00 1B 00 8A 28 .....D....(....(
002F10 00 1B 00 8A 34 00 1B 00 8A 34 00 1B 00 8A 4C 00 ....4....4....L.
002F20 1B 00 0F 00 00 00 8A 4C 00 1B 00 8A 02 00 00 00 .......L........
002F30 06 02 00 00 00 .....
I believe that your serial port settings are not correct or the manufacturer is using its own custom protocol. This isn't IEC62053-21 or DLMS.
