Gurux.Serial
Log in to post new content in the forum.
Topic / Topic starter | Replies |
Last post![]() |
Sticky:
Introducing GXSerial by Gurux Ltd » Tue, 11/24/2009 - 09:10 |
6 |
by Kurumi Tue, 10/01/2019 - 08:41 |
Communicating with Secure Saral over DLMS using pyhon by anildhyani82 » Fri, 12/25/2020 - 11:58 |
1 |
by Kurumi Mon, 12/28/2020 - 14:00 |
i need connect DTZ27 to Gurux ? by enhee88009932 » Thu, 10/22/2020 - 04:47 |
9 |
by Kurumi Thu, 10/22/2020 - 12:45 |
How to ignore AssociationView by using stored XML by ton.tanasin » Wed, 10/14/2020 - 10:56 |
2 |
by ton.tanasin Sat, 10/17/2020 - 04:54 |
I Can't connect Elster A1800 with GXDLMSDirector via RS232 by nikorn » Tue, 09/29/2020 - 13:28 |
9 |
by Kurumi Thu, 10/15/2020 - 20:27 |
how to read data end send request. DTZY217 i need reed parameters by enhee88009932 » Thu, 09/17/2020 - 08:11 |
3 |
by Kurumi Thu, 09/17/2020 - 10:48 |
Protocol question by patm » Wed, 09/09/2020 - 00:12 |
3 |
by Kurumi Thu, 09/10/2020 - 08:16 |
Not readable by gzpmanish » Sun, 09/06/2020 - 08:36 |
1 |
by Kurumi Mon, 09/07/2020 - 10:11 |
How to Identify Start and End of frame by Bhaumik » Thu, 08/20/2020 - 10:06 |
1 |
by Kurumi Thu, 08/20/2020 - 11:13 |
Server address by silent_7 » Thu, 07/16/2020 - 13:05 |
3 |
by Kurumi Thu, 07/16/2020 - 15:48 |
How does DLMS get notification that received data is completed? by KhushbuBadheka » Tue, 07/07/2020 - 08:05 |
6 |
by Kurumi Thu, 07/09/2020 - 18:40 |
Unable to change APN (OBIS code 0.0.155.1.1.255) by manju_guru » Sat, 06/13/2020 - 20:40 |
2 |
by Kurumi Mon, 06/15/2020 - 12:52 |
Trying to get a reading of a landis+gyr e650 (Page: 1, 2)
by ilhan » Tue, 01/14/2020 - 18:19 |
81 |
by Kurumi Fri, 06/12/2020 - 08:32 |
DLMS Meter simulator - Serial by Firas » Thu, 06/04/2020 - 12:17 |
1 |
by Firas Thu, 06/04/2020 - 14:27 |
Physical Address in Client Example by kamerdack » Fri, 03/20/2020 - 15:10 |
7 |
by Kurumi Tue, 05/19/2020 - 08:14 |
Unable to load data by nezar.karem » Wed, 04/29/2020 - 06:11 |
17 |
by Kurumi Thu, 04/30/2020 - 19:07 |
To Get Push data and events over serial interface by Bhaumik » Sat, 04/11/2020 - 10:54 |
8 |
by Kurumi Wed, 04/29/2020 - 07:58 |
Use DLMS server over serial interface by Bhaumik » Fri, 03/27/2020 - 09:00 |
11 |
by Kurumi Wed, 04/01/2020 - 12:16 |
Can not load Gurux.Common.dll and Gurux.Serial.dll for .Net Core project by KhushbuBadheka » Mon, 03/30/2020 - 07:52 |
7 |
by KhushbuBadheka Mon, 03/30/2020 - 14:19 |
Authentication by gzpmanish » Wed, 03/04/2020 - 09:03 |
11 |
by Kurumi Fri, 03/06/2020 - 09:20 |
How to read meter data from smart meter through uart by sreeraj » Tue, 10/01/2019 - 09:05 |
13 |
by Kurumi Tue, 02/04/2020 - 08:03 |
Firmware Upgrade Association by Bhaumik » Mon, 01/20/2020 - 12:49 |
3 |
by Kurumi Mon, 01/27/2020 - 14:59 |
DLMS - Serial - HDLC by StudiEng » Fri, 01/17/2020 - 11:42 |
3 |
by Kurumi Fri, 01/17/2020 - 16:57 |
Access Error : Device reports a unavailable object. by Bhaumik » Thu, 12/05/2019 - 13:21 |
5 |
by Kurumi Thu, 12/12/2019 - 14:33 |
reading by time period - SL7000 ITRON SL761X240 by Matias Ferri » Wed, 12/04/2019 - 14:04 |
3 |
by Kurumi Thu, 12/05/2019 - 10:49 |
