We are writing the capture objects for Testing Scroll Sequence (0-0:21.0.2.255) and I found 2 errors.
It is very common to get the following error: "Index was out of range. Must be non-negative and less than the size of the collection parameter name:index"
Despite of the error seen in Gurux, the meter is changing the testing scroll sequence correctly.
It happens for example when I open Gurux, then read the object 0-0:21.0.2.255 and delete one Capture Object and then write.
If I delete all the objects, and then add one and write to the meter, and then doing the another 6 in the same way there is no error.
While doing these tests, (sometimes) I found another error. I sent only two display (capture objects), but Gurux sent 9 capture objects. Meter received 9 capture objects.
After getting an error message, I delete all objects and then added one by one (without writing after add each one). Result: Sometimes Gurux doesnt update correctly the number of capture objects and send more than the visible in the capture object tab.
I believe that I know the reason for this. You should read capture objects again ("Press F5") after you have modified them. I check if this can be done automatically if capture objects are modified.
